Wayne,
Thanks for help. Also, if you don't mind one more question, on the
Stewart-Warner fuel float senders installed in the root rib, do you use any
kind of sealer to coat the rubber(?) gasket, or just install it dry?
Thanks again.
Roger #687R
Eugene, OR USA
Fuel tank pressure testing.
If it's the cork one I use a light coat of Aviation Gasket sealer. If the
newer neopren/rubber style ones, I installed bare.
From: "Roger and Alice Hoffman" <rognal@mindspring.com>
Sent: Monday, June 18, 2001 9:12 AM
Subject: Fuel tank pressure testing.
anyWayne,
*-------------------------------------------------------------------------*kind of sealer to coat the rubber(?) gasket, or just install it dry?
Thanks again.
Roger #687R
Eugene, OR USA
*-------------------------------------------------------------------------*You have received this message because you have subscribed to the
murphy-rebel mailing list.
