Guys,
I think I need to put anchor nuts on the rear spar of the wing to hold the
flap hinges. Some of those hinges will be bolted onto the wing tanks. Are
there any anchor nuts that are sealed? If so, where does one find them? If
not, how do you affect a seal?
Appreciate the help.
Cheers, rj
R J Thomas
Lafayette, LA
rj.thomas@halliburton.com
(337) 849-4136
Super Rebel N140SR
Anchor nuts
Anchor nuts
In a message dated 5/11/01 9:44:37 AM Central Daylight Time,
rj.thomas@Halliburton.com writes:
RJ
contact Wayne at [http://www.irishfield.on.ca/products.htm] I know he's
talked of the same system and I'm pretty sure he has the hardware at a
reduced cost.
Phil&Lisa Smith #460 N414D
RJ
reduced cost.
Anchor nuts
The sealed nut plates can be purchased from Spencer Aircraft in Seattle
1-800-424-1160, 206-763-0800. The catalog lists two NAS1473A# Steel Nut &
Shell-Alum. or Steel Washer and NAS1474A#Alloy Steel CAD Plating . They have
#440, #632,#832,#1032, and 1/4-28. I don't remember for sure but think I
went with the CAD plated steel, the cost was around $2 each. These nut
plates have a O-ring seal, I also used proseal around the cap as extra seal.
Al Paxhia, SR 26
Sent: Friday, May 11, 2001 7:42 AM
Subject: Anchor nuts
Al Paxhia, SR 26
AreGuys,
Ifthere any anchor nuts that are sealed? If so, where does one find them?
*-------------------------------------------------------------------------*not, how do you affect a seal?
Cheers, rj
R J Thomas
Lafayette, LA
(337) 849-4136
Super Rebel N140SR
*-------------------------------------------------------------------------*You have received this message because you have subscribed to the
murphy-rebel mailing list.
Anchor nuts
Hi from Calgary
If your super rebel is like my rebel, there are bulkheads between the ribs
which is the back of the fuel tank. The tank does not extend to the rear
spar where the aileron hinges are bolted.
Good luck.
REBEL 505
Good luck.
REBEL 505
Anchor nuts
The Super Rebel fuel tanks span the complete distance from the main spar to
the rear spar (making the SR wings actually easier to build than the plain
old Rebel!) and the torque tube is run through the leading edge ribs, not
the rear area of the wing that necessitate the bulkheads in the Rebel tanks.
Sent: Thursday, May 17, 2001 12:19 AM
Subject: Re: Anchor nuts
*-------------------------------------------------------------------------*Hi from Calgary
Good luck.
REBEL 505
Anchor nuts
I did say "IF" the fuel tank was the same as the rebel. Thanks Wayne I did not mean to mislead anyone
REBEL 505
REBEL 505
