Are any of you (building the Rebel) putting an inspection hole in the root
area of the leading edge skin, to access the bolts/nuts of the front
spar/root rib attach fittings?
I asked MAM about it and was told "The bolts you are concerned about do not
require access once they're in there in....Cutting a hole in the leading
edge to access them unnecessarily is a step backward in your construction."
I'm not comfortable 'not' being able to inspect these during the annual
inspection. I was considering a small inspection hole access plate similiar
to those in the bottom skin at the flaperon hinges.
I was just wondering what other builders were doing in this area and I would
appreciate any comments.
Roger #687R
Eugene, OR USA
Inspection Hole in leading edge
Hi Roger
I asked Bijan (tech support) the same question a few years ago and he
advised me not to do this. Apparently this area is fairly critical and a
thorough stress analysis etc. would be required. Reading between the
lines, I concluded this would entail some serious reinforcement etc. and
then who knows what surprises might be caused by the mods.
I contented myself with some torque seal lacquer (paint) on the
nuts/bolts that can be seen from the wing root end of the wing. And of
course, torquing the bolts to the upper end of the recommended range.
Hi Roger !
I agree fully with Ken !! The leading edge, ESPECIALLY at
the root, is a VERY critical area. I definitely would not cut ANY
extra holes there !! The whole wing root area, out to at least
3 ribs, is VERY important to overall strength, and no changes should
be made there without checking with the factory....
---------------------------orig.---------------------------------------
Hi Roger
Roger and Alice Hoffman wrote:*-------------------------------------------------------------------------*Are any of you (building the Rebel) putting an inspection hole in the root
murphy-rebel mailing list.
