auto engines weight & balance
Legeorgen
Post by Legeorgen » Fri Feb 17, 2012 8:55 pm
Hey everyone,
Just for clarification, the Wheeler of NSI (the bad guy) and the Wheeler of
the "Wheeler Express" airplane are two different people and companies. By the
way, the Wheeler of the Wheeler express airplanes went bankrupt after the
first two demo planes had fatal accidents. He was unable to sell planes and
get backing for his company after that. The rights for the plane (which is
really a nice craft) were sold.
Bruce G
David M Parrish
Post by David M Parrish » Fri Feb 17, 2012 8:55 pm
On 1 May 2001, at 19:39, klehman@albedo.net wrote:
psru is a must. Avoid their older sprag clutch psru. While the ej33 is
an amazing engine I prefer a more conservative approach rather than
tweaking to the max at 6000 rpm. Crossflow does know how to get the
The EG-33 is 243HP @ 6000 (From a Subaru torque graph),
230HP @ 5400 (Which is where US engines are listed) and 211HP
@ 4800. (Torque peak) These are all stock power ratings.
How much power do you want?
In this power range there is much to be said for a Chev V-8 or
Corvette LS-1 when things need to be repaired or serviced. Firewall
Wouldn't those be much heavier than an EG-33? When Velocity
tested the EG, their airplane weight was 40lbs more than with it's
original IO-360. (And that's with the stock 17lb intake manafold.)
True, a LS-1 will produce more power.
Egenfelner and Stratus have web sites but I am not aware of them
selling the ej33. Dave at Subie-Lyc might have mentioned doing one
though.
EG-33's are fairly rare, since they were only in the Subaru SVX,
which didn't sell very well in the US. What holds potential is the H6
engine that's in the new LL Bean Forester. 210HP @ 6000RPM,
and only 1 inch longer and 100lbs heavier than the EJ-25 four. If the
new Forester is popular (hope, hope), then the engine might
migrate to other models, making it even more available and
cheaper in the future.
David Parrish
klehman
Post by klehman » Fri Feb 17, 2012 8:55 pm
Yes your numbers are correct for the Subaru eg33 but tweaking to over
300 hp with turbos and runnning a high ratio psru (2.4:1??) is a big
increase. Personally I'd like to see some demonstrated in-flight
reliability at those levels before betting something like $20k and my
butt on one. Probably very workable though with a good intercooler, a
varible pitch prop and a reasonably low cruise power.
All the weights I've seen are 300+ lb for the longblock and 400+
installed for an eg33 conversion which is in the same range as even an
LS-1 as I understand it. I'm a Subaru believer but I've also seen a few
replaced with Lycomings due to teething problems. I also tend to drool
when I look through a Summit Racing catalog and see how many of my
problems could be solved for very little money if I were using a Chev.
And brand new Chev longblocks are also available complete with a high
speed marine camshaft for the cost of a used eg33. I've already scrapped
one low time ej22 due to overhaul costs and it is a much more popular
engine than the eg33...
Yes an eg33 will be heavier than an 0-360 but you need to carry less
fuel, so it can still be worth considering. And I'd rather use an eg33
than a tweaked to the max smaller engine. I'm just not convinced that a
souped up 33 is the very best option for someone wanting 300 hp on an
SR.
Mike Davis
Post by Mike Davis » Fri Feb 17, 2012 8:55 pm
I myself have all but decided that the eg33 is the way that I will go with
my SR, but another engine to consider in this discussion is a Mazda 20B
rotary. Atkins Rotary offers one turbo charged at a reported 350HP.
www.AtkinsRotary.com Since the SR3500 has come into being that Chevy LS-1
is looking better too... it sure would be a shame to build that monster and
only put 300HP on it.
Mike Davis
Sent: Wednesday, May 02, 2001 8:45 AM
Subject: Re: auto engines weight & balance
SR.
murphy-rebel mailing list.
bob.patterson
Post by bob.patterson » Fri Feb 17, 2012 8:56 pm
Received: from rossine.total.net ([154.11.89.167])
by dcsol.com (wcSMTP v5.4.449.4)
with SMTP id 196086593; Mon, 07 May 2001 07:58:44 -0800
Received: (qmail 3860 invoked from network); 7 May 2001 15:58:35 -0000
Received: from unknown (HELO ip123.toronto79.dialup.canada.psi.net) (154.20.73.123)
by smtp.total.net with SMTP; 7 May 2001 15:58:35 -0000
X-Sender: crs1188@209.89.75.25
Mime-Version: 1.0
Subject: RE: auto engines weight & balance
Hi Mike !
I was talking to Crossflow at the Toronto Aviation Show.
Apparently, there is at least one Super Rebel already flying with
a six-cylinder Subaru, and they have another one very close to
flying (another month ...).
They certainly have a nice shop, and have been building
racing engines for many years. They are now making their own re-drive,
rather than using the Marcotte drive. They had an engine at the
show with an M-T 3 bladed constant speed prop - very nice !
----------------------------------orig.----------------------------------
Anybody have any comments about Crossflow? I was going to go with them for
my Super Rebel since they have a complete firewall forward package. Hoping
to get the 320HP turbo'd engine. Can anyone provide info on how to contact
Stratus and this Eggenfellner person for comparison shopping? Or do they
even deal with the high horsepower Suburus?
SR#044
bob.patterson@canrem.com
Sent: Sunday, April 29, 2001 5:38 AM
Received: from bretweir.total.net ([154.11.89.176])
with SMTP id 68454468; Sun, 29 Apr 2001 05:37:30 -0800
Received: (qmail 13161 invoked from network); 29 Apr 2001 13:37:21 -0000
Received: from unknown (HELO ip27.toronto77.dialup.canada.psi.net)
(154.20.71.27)
by bretweir.total.net with SMTP; 29 Apr 2001 13:37:21 -0000
Mime-Version: 1.0
DON'T EVEN <THINK> about talking to NSI - unless you really want
PAIN !! We've met several people who sent them money and got NOTHING !!
They have unhappy people all over the world !
Dave Bangle, at SubieLyc, in Montana, or the folks at Stratus,
in Seattle (I think), are good people who do nice work, and ACTUALLY
DELIVER. And there are several Rebel builders here on the list who
can give you all kinds of sugestions and help, as they are happily
flying their Subarus !
------------------------------orig.------------------------------------
Hi bobp:
Thanks for the reply. I will look at the EJ22.
I'm going to Arlington ( not quite Oshkosh but closer) & will be talking to
NSI. Will inform the site when I get back. Thanks again for your reply.
REBEL 505
Drew and Jan
Post by Drew and Jan » Fri Feb 17, 2012 8:56 pm
Renessance aviation in Centralia has built a mould and is supplying
cowlings for super rebels with subarus as part of the crossflow firewall
forward kit. If anyones using a subaru from another source and is
interested I will contact them and ask if they'll sell directly to builders.
Hi Mike !
