SR 3500 Upgrade Kit
Don Boardman
SR 3500 Upgrade Kit
Post by Don Boardman » Fri Feb 17, 2012 8:48 pm
Hi All,
Just thought I'd pass along some feed back on the SR 3500 upgrade kit.
I received the upgrade kit for the Tail Feathers and Wing today.
I have inventoried all the parts and reviewed the instructions.
My first impression is that Murphy has done a fine job. Beefy is a word that
comes to mind, along with "quite doable". My tail sections' structures
where/are complete but the skins are not installed. Not having the skins
installed is an advantage but even with skins installed the job doesn't look
to bad. I have a fast build 2500 wing. In it's state of semi completion as
delivered from Murphy the modifications once again seem straight forward.
No information on the fuselage mods as I will be getting a fast build 3500
fuselage when my turn comes.
If you are on the fence about upgrading you might get Murphy to send you a
copy of the instructions which give a very clear view of what's involved.
Again I have only seen the tail and wing instructions.
Happy Building,
Don Boardman
Rome, NY
SR130
bob.patterson
SR 3500 Upgrade Kit
Post by bob.patterson » Fri Feb 17, 2012 8:48 pm
Received: from bretweir.total.net ([154.11.89.176])
by dcsol.com (wcSMTP v5.4.449.4)
with SMTP id 13088062; Mon, 02 Apr 2001 18:42:50 -0800
Received: (qmail 21764 invoked from network); 3 Apr 2001 02:42:44 -0000
Received: from unknown (HELO ip14.toronto77.dialup.canada.psi.net) (154.20.71.14)
by bretweir.total.net with SMTP; 3 Apr 2001 02:42:44 -0000
Mime-Version: 1.0
Subject: Re: SR 3500 Upgrade Kit
Thanks for the encouraging words, Don !!
Please keep us posted as you progress ....
----------------------------orig.----------------------------------------
At 09:52 PM 4/2/01 -0400, you wrote:
Hi All,
Happy Building,
Don Boardman
Rome, NY
SR130
murphy-rebel mailing list.
