FUS-12 Witches Hat
randrews
FUS-12 Witches Hat
Post by randrews » Mon Nov 05, 2012 12:33 pm
Is Murphy the best source for FUS-12 Witches Hat ?? ... just need a 4' stick, anyone have extra they can part with or know a good source ??
tjhickey
Re: FUS-12 Witches Hat
Post by tjhickey » Mon Nov 05, 2012 7:40 pm
I am too would like to get some of that material. Any local source in the US?
Tim Hickey
Montrose, Iowa
319 795-2684
Post by irishfield » Mon Nov 05, 2012 9:59 pm
Two ways to get it.. order from Murphy or bend it up yourself from sheet stock. It's not a common part that anyone else is making/using, it's a part Murphy bends up specifically for it's fleet of a/c and floats.
Post by snowyriver » Mon Nov 05, 2012 10:49 pm
Wayne's right. It's easy to bend up a section. Spruce also sells some if I recall.
tjhickey
Post by tjhickey » Tue Nov 06, 2012 7:53 am
ACS material is 20K, and forming such without a press-brake not so easy. But I'll be glad to take a lesson as to how it can be done with a folding apron brake.
Tim Hickey
Montrose, Iowa
319 795-2684
randrews
Post by randrews » Tue Nov 06, 2012 10:54 am
Agree on the need for a press break ... just remembered MFC has a huge press brake that could make this stuff ... maybe Keith has some. If not, I'll go direct via email to Murphy. Regardless, think a close reproduction of the actual FUS-12 could be done on an apron brake ... with a lot of part flipping and sequential partial bends ... but getting the correct on-center bends would be tough. Appreciate the feedback ... thanks. Bob A.
randrews
Post by randrews » Tue Nov 06, 2012 12:18 pm
Aside from the entertainment value my ignorance may have provided ... while a press brake can certainly make them, its not required. They can be made fairly easily on a pan or box brake. With the material thickness in hand, its a matter choosing the right fingers, looking up the correct finger offset based on the desired bend radius and material thickness ... and then bending. Now I just need to find a brake ... :) Cheers, Bob A.
tjhickey
Post by tjhickey » Tue Nov 06, 2012 7:53 pm
I have a homemade brake, built from plans provided by Zenair when I built my CH-300 25 years (ouch) ago. I can, and have, formed the edge bends, and tomorrow I will trot down to the local fab shop and see if they can form the center bend. Please ignore the fancy handle on the brake. Some things just never seem to get finished.
Tim Hickey.
Tim Hickey
Montrose, Iowa
319 795-2684
Post by snowyriver » Tue Nov 06, 2012 9:53 pm
You can make these with a regular brake. Bend the center section first. Look at this photo: The stiffeners under my floor are nothing but small W hat.
