[rebel-builders] Oil Pressure sending unit on M14-P
Ted Waltman
Post by Ted Waltman » Mon Feb 20, 2012 2:36 am
Larry,
You should be able to hook up the sending unit to the output side of the oil
pump (above the fuel pump, on the back, right-hand side of the engine,
basically behind the carb). I can dig around a look for pictures of mine or
take some later this week for you.
Ted
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Larry
Sent: Monday, January 09, 2012 1:23 PM
Subject: [rebel-builders] Oil Pressure sending unit on M14-P
Hello, I am hooking up the instruments on my M14-P, I have the Western
fitting kit from Jim Kimball, I can't figure out where to tap into the oil
pressure system to hook up the sending unit. Please advise.
Larry Luckinbill
S R 117 Moose
password "builder"
