Elite exhaust.
PHILIP H ABLITT
Elite exhaust.
Post by PHILIP H ABLITT » Fri Feb 17, 2012 8:39 pm
To All,
Can anyone tell me if Vans RV6 exhaust will fit under the Elite cowling without modification?
Phil Ablitt
Legeorgen
Elite exhaust.
Post by Legeorgen » Fri Feb 17, 2012 8:39 pm
Any one know if a crossover exhaust for a Glasair fits in the fiberglass cowl
for the Rebel?
Bruce 357R
Contributors' page at:
Visit the book store at:
Elite exhaust.
Post by Wayne G. O'Shea » Fri Feb 17, 2012 8:39 pm
Your following message has been delivered to the 182 members of
the list murphy-rebel@dcsol.com at 23:21:39 on 9 Jan 2001.
Phil and Bruce, I'm sure the RV exhaust will fit the MAM speed cowling as
MAM is not longer making their own and instead supplying (beautiful)
exhausts built by Forester or Fosslington (some darn name that starts with
F) that builds the exhausts for the RV's. They have exhaust stubs that have
slip pegs to lock them to the pipes, but still allow for
expansion/contraction and a ball joint to allow pointing the exhaust outlets
in the right direction. The Glasair exhaust probably works fine too, as it
is a closely cowled aircraft also.
Sent: Tuesday, January 09, 2001 10:30 PM
Subject: Re: Elite exhaust.
cowl
for the Rebel?
Bruce 357R
BILNEWKIRK
Elite exhaust.
Post by BILNEWKIRK » Fri Feb 17, 2012 8:39 pm
I TRIED THE RV-6 EXHAUST ON MY REBEL AND FOUND THAT MY ENGINE IS MOUNTED
CLOSER TO THE FIREWALL THAN THAT OF AN RV. tHEREFORE, IT WOULD NOT CLEAR THE
BOTTOM OF THE FIREWALL.
BILL N
#376
Elite exhaust.
Post by Bob Patterson » Fri Feb 17, 2012 8:39 pm
Hi Phil !
I don't believe that it will. The stainless exhaust that
Murphy sells is made by the same company, and i think a couple of
measurements were changed. (position of the ball joints, length of
tubes ...)
----------------------------------orig.---------------------------------
At 06:36 PM 1/9/01 -0800, you wrote:
To All,
Phil Ablitt
<HTML><HEAD>
<META http-equiv=Content-Type content="text/html; charset=iso-8859-1">
<META content="MSHTML 5.50.4611.1300" name=GENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=#ffffff>
<DIV><FONT face=Arial size=2>To All,</FONT></DIV>
<DIV><FONT face=Arial size=2>Can anyone tell me if Vans RV6 exhaust will fit
under the Elite cowling without modification?</FONT></DIV>
<DIV><FONT face=Arial size=2></FONT>&nbsp;</DIV>
<DIV><FONT face=Arial size=2>Phil Ablitt</FONT></DIV></BODY></HTML>
Elite exhaust.
the list murphy-rebel@dcsol.com at 15:29:53 on 10 Jan 2001.
Sorry that I provided misleading information, if what Bob says below is
true!!! I had been told the Exhaust being supplied was the same as either
the RV-4 or RV-6's (maybe they just meant the same guy that builds the RV
stuff). I'm sure though, if you already have the exhaust for the other
"breed", with a cutter and pipe expander to put it back together you can
make it fit to save the Thousand $'s.
Sent: Wednesday, January 10, 2001 10:26 AM
Hi Phil !
tubes ...)
To All,
Phil Ablitt
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
fit
Legeorgen
Elite exhaust.
Bill,
Did your RV6 exhaust have the ball joints at the tail pipes to adjust them
down to clear the firewall?
Bruce 357R
