Fuel Tank
C&P Kucera
Fuel Tank
Post by C&P Kucera » Fri Feb 17, 2012 8:40 pm
------=_NextPart_000_0042_01BF6C3A.96795420
Content-Type: text/plain;
charset="iso-8859-1"
Hi Bob.
Look at the attached tank used on the new Cessnas. The only thing different
from the Rebel tank is the yellow color, some kind of primer, not sure if it
is alodine or something else.
When mixing ProSeal follow instruction and use degreased tools and dishes.
Watch for condensation and air tool oil spray.
Have fun building!
Paul Kucera
Rebel 453R
Sent: Sunday, January 30, 2000 5:54 PM
Subject: New Member
Hi All,
This is my first note to the Rebel Builders web site. I talked to
the patron saint of Rebel Builders, Bob Patterson, at Oshkosh 1999.
I have Rebel Kit 429. I started construction in Minnesota, and then
moved to the Chugiak, Alaska in 1996. My Rebel is now in its third
house/garage workshop. Moving to a new home sure slows building. I
also bought a 1966 Citabria 7ECA to explore Alaska in while I was
building. On the first annual, I had to buy a new rudder and right
elevator frame and recover them. It also needed a legal radio and
GPS. It reminded me why I ordered the Rebel kit in the first place.
I wanted to have a new airframe, not a 35 year old one. So far I have
built the control surfaces, vertical and horizontal stabs and have
started on the wings. I have a question on the fuel tanks. I met a
gentleman in Oshkosh some years back who built aluminum fuel tanks on
his Rebel. He was from Texas. I know MAM does not support this because
it removes ribs in the wing bays. It does stop the fuel leaks,
however. Has anyone else made aluminum tanks or is the traditional
wet wing and proseal process the best? Is the standard fuel tanks
enough fuel and range for the northern lattitudes where gas can be
expensive and sometimes hard to find? I plan on using a O-320 engine.
Since I have just finished rebuilding my work table, a note to Roger
Hoffman: My table is perhaps overbuilt, but it is solid. I made the
table in two 4X8 sections that slide together. The legs are 4X4 posts
and I have a 2X6 frame on 16 inch centers on the top to support the
plywood top and also on the bottom to hold the parts and boxes. It was
easy to build and level. Be sure to leave a overhang space of 1/2 to a
inch on the sides so you can clamp parts to the table to work on.
Finally, a question. I have been saving the builders tips on my hard
drive. Do I need to do this or are all the notes sent to the archives?
Thanks for all the great tips and encouragement.
Bob Brennan
Rebel 429
Content-Type: application/octet-stream;
name="Cessna tank.jpg"
Content-Transfer-Encoding: base64
Content-Disposition: attachment;
filename="Cessna tank.jpg"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------=_NextPart_000_0042_01BF6C3A.96795420--
Rebel582
Fuel tank
Post by Rebel582 » Fri Feb 17, 2012 11:46 pm
I am getting ready to make the angles to plug the stringer cutouts and
noticed that if made to instruction specifications they will extend past the
stiffening swage. Should I make them smaller or try to get a good fit by
trying to bend them to lay flush on the rib?
AGT
Fuel tank
Post by AGT » Fri Feb 17, 2012 11:46 pm
I just made them to fit on the flat parts of the rib. You just need to plug
the hole with metal as best you can so that the entire hole doesn't have to
be plugged with a huge proseal dam. Anything you fabricate that closes the
hole off well so that the proseal doesn't have to do the whole job should
work. I have read on the list that you don't want the cut out for the
curved part of the stringer to fit too well because you want some proseal to
be able to squish in there and make a good seal.
From: MURPHY-REBEL@dcsol.com [mailto:MURPHY-REBEL@dcsol.com]On Behalf Of
Rebel582@aol.com
Sent: Thursday, February 22, 2001 3:23 PM
To: MURPHY-REBEL@dcsol.com
Subject: Fuel tank
Fuel tank
Post by Ralph Baker » Fri Feb 17, 2012 11:46 pm
I just went through this happy excercise. I fitted the angles around the
stiffening swage so the angle is flat on the rib surface. There is no
other way to get a good seal. The swage contour can be easily cut on a
bandsaw with 1/4" blade and then finally filed to exact contour. the
easiest way I found to cut the "J" was with a Dremel tool and a 1/8"
diameter cylindrical carbide cutter. Also made a helpful "tool" from a
scrap of stringer to press up against the angle to mark the "J" dimension
to be cut. Be sure to "float" the angle on the stringer and let the
stringer position the angle on the rib. The stringer is closer to one side
of the rib cutout so be sure when you drill the rivet holes you drill into
the rib and not the cutout.
Elite 611E
Mike Davis
Fuel tank
Post by Mike Davis » Fri Feb 17, 2012 11:46 pm
Ralph, I saw that you posted this message to both the "murphy-rebel" and the
"murphy-rebel-d" lists... thought I'd take a minute to explain how this
works. There are 2 lists for the purpose of defining how a member receives
their messages, either individually, or in blocks of 10. You are only a
member of one or the other. Both lists are associated with the same message
area on the system, so a message posted to either list will be distributed
to the members of both lists. I would imagine that you received an error
back from the system because you were not a member of one of the lists.
In the future all you have to do is post your message to the list you are a
member of. If you are replying, then the correct address will be filled in
for you. I know this is different than the old system, and a little
confusing now, but once you're used to sending to the correct address, it
should be pretty simple.
To: <MURPHY-REBEL@dcsol.com>
Cc: <murphy-rebel-d@dcsol.com>
Sent: Thursday, February 22, 2001 6:52 PM
Subject: Fuel tank
side
Elite 611E
roger
Fuel tank
Post by roger » Fri Feb 17, 2012 11:47 pm
I'm working in this area now, also. I fabricated the stringer cutout clips
as Terry Dazey did his. If
you were to go to NW Rebel Experimental Aircraft site at the following link
you can see his
photograph:
http://beta.content.communities.msn.com ... ommunity=N
WRebelExperimentalAircraft&ID_Topic=14&ID_Message=115
R. Hoffman #687R
Eugene, OR USA
Received: from imo-d09.mx.aol.com ([205.188.157.41])
by dcsol.com (wcSMTP v5.4.449.1)
with SMTP id 145567859; Thu, 22 Feb 2001 15:22:38 -0900
Received: from Rebel582@aol.com
by imo-d09.mx.aol.com (mail_out_v29.5.) id b.88.2c13319 (4251)
for <murphy-rebel@dcsol.com>; Thu, 22 Feb 2001 19:22:35 -0500 (EST)
Message-ID: <88.2c13319.27c7074a@aol.com>
Date: Thu, 22 Feb 2001 19:22:34 EST
Subject: Fuel tank
MIME-Version: 1.0
Content-Type: text/plain; charset="US-ASCII"
X-Mailer: AOL 5.0 for Windows sub 129
apat
Fuel tank
Post by apat » Fri Feb 17, 2012 11:47 pm
Received: from smtp.interlog.com ([154.11.89.176])
with SMTP id 27398718; Sat, 24 Feb 2001 06:42:00 -0900
Received: (qmail 3312 invoked from network); 24 Feb 2001 15:41:56 -0000
Received: from unknown (HELO ip121.toronto77.dialup.canada.psi.net) (154.20.71.121)
by bretweir.total.net with SMTP; 24 Feb 2001 15:41:56 -0000
Mime-Version: 1.0
Subject: Re: Fuel tank
Thanks Roger, but THIS is one of those stupid, arrogant web sites that
won't even let you see the pages unless you have the "latest & greatest"
web browser !!
I don't understand people who want the public to visit their
sites, then make it impossible !! Usually, they are Micro$oft victims,
who are so brainwashed they think M$ is the only O/S and browser mfg.
in the world !!
Sorry for the tirade - I've just had a day full of these idiots !
----------------------------orig.-----------------------------------------
you can see his
photograph:
http://beta.content.communities.msn.com ... ow_photo&I
D_Community=N
R. Hoffman #687R
Eugene, OR USA
Subject: Fuel tank
MIME-Version: 1.0
carol51
Fuel tank
Post by carol51 » Fri Feb 17, 2012 11:47 pm
Rebel 505
The root rib gussets are bent 90 deg. I made mine big enough to put two
rivets each side of flange and 3 rivets thru side of rib. In outer solid
tank rib again I bent mine 90 deg. long enough to get 2 rivets in flange on
each side.I drilled a 1/4 inch hole at a location which will allow the top
of the stringer to be flush with the rib flange on top.To do this you must
file the gusset down 1/16 in the centre the width of the stringer. I cut the
gusset to follow the curve of the buldge in tne rib. Put 3 rivets in side of
rib.
The corner gussets are well illustrated in the manual.
GOOD LUCK
Mike Davis
Fuel tank
Post by Mike Davis » Fri Feb 17, 2012 11:47 pm
Gosh Bob... even Netscape on Linux will view these pages. That is if you're
at least running a version that's newer than that Lycosaurus technology
you're flying behind!
Sorry, but figured you've had a few days to cool off, so it should be safe
to pick on you a little.
By the way, I hope you noticed that the new archive site still supports
dinosaurs like you, while also offering truly usable features to those who
are even close to keeping up with the times. :-)
Sent: Saturday, February 24, 2001 6:42 AM
web browser !!
in the world !!
clips
link
you can see his
photograph:
D_Community=N
R. Hoffman #687R
Eugene, OR USA
Subject: Fuel tank
MIME-Version: 1.0
past the
by
apat
Fuel tank
with SMTP id 382110453; Wed, 28 Feb 2001 09:13:52 -0900
Received: (qmail 25400 invoked from network); 28 Feb 2001 18:13:49 -0000
Received: from unknown (HELO ip135.toronto81.dialup.canada.psi.net) (154.20.75.135)
by bretweir.total.net with SMTP; 28 Feb 2001 18:13:49 -0000
Mime-Version: 1.0
Well - - I'm still having problems with my stupid ISP, and
CAN'T connect with LINUX <AT ALL> !!! So I've fallen back to
an old box with WinDoze 3.11, and Netscape 3.0 - works well on
many sites (at least, the thoughtful ones).
I can get onto the new dcsol site, and read archives, etc.,
but I DO get scattered .jpg icons over the text in places, and other
little anomalies. Part of this is because I run with Java and JavaScript
turned OFF - I really don't need flash & dazzle, OR viruses !!
Just a real old stick in the mud, I guess - still like plain
text interfaces. (Still do lots of work in FoxPro (NOT <visual>) !!)
Sorry - still haven't completely chilled ! Get tired of
fighting the M$ machine - but their days are numbered .... I think
even Bill G. realizes it's all downhill from here !! Thank goodness !!
-------------------------------orig.------------------------------------
web browser !!
in the world !!
clips
link
you can see his
photograph:
D_Community=N
R. Hoffman #687R
Eugene, OR USA
past the
by
Charlie Eubanks
Fuel Tank
Post by Charlie Eubanks » Sun Feb 19, 2012 2:38 pm
Hello All
I am just getting a good start on my Rebel wings and have a couple of
questions about the fuel tank construction.
Does anyone have a good technique to get the tank ribs reasonably straight
and flat? Mine are really quite bent; due I am sure to all the cold forming
they are subjected to and without the cutouts the other ribs have to relive
the captured stress.
My previous project was a Glastar and because of its folding wing feature it
only has one fuel outlet per wing tank. The fuel capacity was 33 Gal. with
only 27 Gal. useable. In a descending glide with only 3 Gal's remaining in
each tank the fuel lines could un-port long enough to create temporary fuel
starvation. This problem finally became un-acceptable and Glastar's solution
was to add a small vented header tank in series and just down stream of each
wing tank. The header tank had sufficient fuel capacity to keep the engine
running until the nose was raised and the port would close and re-establish
fuel supply.
Since the Rebel also has only one fuel outlet port per tank, I wondered if
anyone has ever had a similar problem? If so what was the solution?
rick greenwood
Fuel Tank
Post by rick greenwood » Mon Feb 20, 2012 2:35 am
I've cut 3"x5" hole on top of fuel tanks,0ne side is proseal ,the other is a light tan colour ,thin surface covering substance.Would this beType A brushable sealant or slosh coating. Rick 233R
