[rebel-builders] European AD for Rotax 912/914 engines
Post by Ralph Baker » Sun Feb 19, 2012 11:34 pm
I cannot open the link. If this is the MANDATORY check for crankcase
cracking around the bearing on 912 and 914 Rotaxes that also came from
RotaxOwner.com. If anyone else can't open Nigels link I will send the AD on
request to rebaker@sc.rr.com.
Sent: Wednesday, November 16, 2011 12:37 PM
Subject: [rebel-builders] European AD for Rotax 912/914 engines
Rotax users may be interested in this just issued over here
http://www.caa.co.uk/application.aspx?c ... 1&mode=det
ail&id=4764
Nig
745E
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2012.0.1869 / Virus Database: 2092/4620 - Release Date: 11/16/11
Post by Wayne G. O'Shea » Sun Feb 19, 2012 11:34 pm
Yes it's the same AD that came out yesterday for UL and Certifed engines.
Only difference in the UK AD is they have listed the serial number of the
crankshaft itself vs the serial number of the engine it is installed in...
and have stated ALL engines are to be inspected for this AD.
Here is the NAmerican AD for those running the UL and ULS engines here.
Serial numbers are up in the 6's and or those that recently had an engine
overhauled. If you are in the batch.. you're grounded!
http://legacy.rotax-owner.com/SI_TB_Inf ... 2059UL.pdf
Stupidity of the AD... if you tear apart and find no crack..... then you are
to bolt it back together and go flying. Reality is you could have only a few
hours on your engine and a crack hasn't formed yet.
Sent: Wednesday, November 16, 2011 1:23 PM
Subject: Re: [rebel-builders] European AD for Rotax 912/914 engines
on
ail&id=4764
Nig
745E
