[rebel-builders] Rebels on Skiis
Post by Wayne G. O'Shea » Sun Feb 19, 2012 11:34 pm
All you need is a set of 1500, 1800 or 2000 federals (all use the same beam)
or similar Craig. All will work.. but a foot wide bottom (= a 2000) would be
great for the deeper/fluffier snow.
Rigging is straight forward..... rear check cable just goes to the rear gear
(drag brace) attach bolt and you can bring your front cable and bungee (or
spring) up to the front attach bolt without issue, or make tabs to come down
off your lower motor mount bolts (at firewall) for them.
I'll find and fire you a couple pics directly.
Sent: Sunday, November 06, 2011 3:59 PM
Subject: [rebel-builders] Rebels on Skiis
So....a subject I haven't seen alot of on this site. Rebels on Skiis.
I'm interested in info anyone has on rigging, do's, don'ts, photos of
installs, etc. I've seen wayne's wheel ski on his site....making a set
of those sounds like a fun project for the future but I'm mainly
interested in straight skiis for now.
Thanks, Craig #207 running strong (very) at 44 hrs!
Well I tried Craig.. but both your old address and your new @ak.net address
both failed saying "unknow or illegal alias".
Sent: Sunday, November 06, 2011 4:37 PM
Subject: Re: [rebel-builders] Rebels on Skiis
beam)
be
gear
down
Post by snowyriver » Sun Feb 19, 2012 11:34 pm
I don't know why, Wayne. I'm getting your other emails. Please try
again when you can. cw
address both failed saying "unknow or illegal alias".
----- Original Message ----- From: "Wayne G. O'Shea"
<oifa@irishfield.on.ca>
same beam)
would be
rear gear
bungee (or
come down
----- Original Message ----- From: <snowyriver@ak.net>
Skiis.
set
You should have it.. let me know!
Sent: Sunday, November 06, 2011 10:39 PM
same beam)
would be
rear gear
bungee (or
come down
Got them. Thanks!
drewjan
Post by drewjan » Sun Feb 19, 2012 11:34 pm
Hey Wayne Is there a formula for ski size. Like how many pounds a square inch of ski surface will support?
Sender: mike.davis@dcsol.com
Date: Sun, 06 Nov 2011 20:56:08
Got them. Thanks!
I had a number figured out on what I thought gave good floatation... lb/sq
inch of ski. I'll have to find my notes....
Sent: Monday, November 07, 2011 1:14 AM
Got them. Thanks!
