[rebel-builders] Moose Structural Failure ! Possible rudder
[rebel-builders] Moose Structural Failure ! Possible rudder flutter (long p
Post by Wayne G. O'Shea » Mon Feb 20, 2012 2:34 am
You already know my thoughts on it Ted and I'll keep them private for now.
Thinking cap is still in motion though..
Sent: Tuesday, October 04, 2011 5:49 PM
Subject: [rebel-builders] Moose Structural Failure ! Possible rudder flutter
(long post)
[quote]I posted two pictures (Area 107 S/M-Fuselage) of my buckled fuselage due to
what I suspect-but have not yet confirmed-is rudder flutter. Below is a
synopsis of the event-from which I and my passengers are blessed to have
survived. I will post more information on this event as I further analyze
the structure while I make repairs--and after I receive input from NTSB
investigators who are looking at the plane in person.
Note: No rudder counter-weight / balancing is required by the build
manual.
The standard rudder is therefore aft (aft of rudder hinge point that is)
heavy. I added electric rudder trim (servo motor & related hardware) as
well as a curved rudder top--both of which add yet more weight aft of the
rudder hinge point.
I believe this video illustrates what happens with a rudder whose weight
is
aft of the hinge point is very telling (47 seconds long-well worth
watching!!): http://tinyurl.com/44p6o35 (when he waves his hand in front
the rudder he is simulating a wind gust).
Rest assured, when I make repairs, I will dynamically balance both my
rudder
and my elevator (which already has some counter-weight but perhaps not
enough?).
Ted Waltman
Moose N384JP Denver, Colorado
Event synopsis
Departed 18V at approximately 7:40 a.m. after filling fuel tanks
completely
full (80.0 total gallons) and checking oil full at 16 quarts. Climbed to
5,500' cruise altitude on heading of approximately 97 degrees magnetic on
direct course to KHYS.
After approximately
