In my wings (only) I used braided sleeving, lighter than any alternative I
could find. A bit of a pain to feed wires through initially, but once I had
a pull through in place (nylon fishing line) it was easy enough as long as
there was a smooth transition from the puller to the start of the wire.
Nig
745E
paul.lennemann@dcsol.com
Sent: 20 August 2011 01:24
Subject: [rebel-builders] Conduits for wiring
I'm thinking about putting lights in the wingtips and top of the fin. I've
been
contemplating putting a 1/2" tube infront of the tip spar and the leading
edge. What else has been done to allow for the wires? Thanks, Paul SR074
I've seen recommendations to tie your nylon fishing line to a cotton ball,
then use your vacuum to pull the cotton ball through the tube -- supposedly
easy.
SR 093
N.Smith
Sent: Saturday, August 20, 2011 2:10 AM
Subject: RE: [rebel-builders] Conduits for wiring
Nig
745E
been
easy.
SR 093
N.Smith
Nig
745E
been
[rebel-builders] conduits for wiring
The cheaper milky white polyethyene tubing from hardware store is
probably a better choice than cpvc. Many of us ran the wires up the
struts for the wing.
Paul, Some have used PVC water pipe. Wayne rejects that vehmently
because of combustion products should there be a fire. I always try
to consider future maintenance and would use conduit / tubing of some
sort for future ease of wire replacement. Consider access and be
sure to tie the conduits down with Adel clamps. Same goes for
supporting the free wire at least every 12 inches. Grommets where
necessary. All relative motion between parts must be stopped or one
will eventually cut the other. Leave a nylon pull string in place as
well for possible future wire pulls. Ralph Baker
I ran a piece of 1/2" PEX (residential plastic water line) down each
wing supported at each rib with a homemade bracket and an adel clamp. I
ran them through the strut as well and protected them with corrugated
loom inside there. Leave some extra length especially once you're
inside the cockpit. The down side of the strut route for me was the
fact that I needed to get AOA, static, and pitot tubing back to the
center of the tailcone. Coming through with wires and stuff at the wing
root level would be easier if you have a similar situation.
As far as a fire hazard there's already a lot of nasty flamable stuff
in the cockpit (seats, interiors, gauge housings, etc). Enough that in
the event of a fire, that 12' long 1/2" tube probably won't be an issue.
I've been contemplating putting a 1/2" tube infront of the tip spar
and the leading edge. What else has been done to allow for the wires?
Thanks, Paul SR074
I posted three pictures to area "106 - S/M Wings."
The first picture (MurphyQuickbuild.jpg) is what happens to the standard way
the factory does the "wiring conduit" on their quick-build kits (at least on
one that I saw personally). Obviously, DON'T do it "their" way!
The second picture (WingWireConduit.jpg) shows the use of conduit in a wing.
Note that we used about a 1" long piece of nylaflow tubing slit lengthwise
to cushion the ziptie on the inner portion of the rib.
The third picture (WingWireStandoff.jpg) shows another approach to build a
stand-off on each rib and zip tie the standard "Murphy flex tubing" to the
stand-off.
Hope this helps,
Ted Waltman
Moose N384JP
Sent: Friday, August 19, 2011 6:24 PM
been
stand-off.
Hope this helps,
Ted Waltman
Moose N384JP
been
While I have the utmost respect for Wayne, I humbly submit that if you have
a fire in the wing, the last thing to worry about is conduit burning up. By
then you are hooped.
Ted
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Ralph
Baker
Sent: Friday, August 19, 2011 7:09 PM
Subject: [rebel-builders] conduits for wiring
Paul,
Some have used PVC water pipe. Wayne rejects that vehmently because of
combustion products should there be a fire. I always try to consider future
maintenance and would use conduit / tubing of some sort for future ease of
wire replacement. Consider access and be sure to tie the conduits down with
Adel clamps. Same goes for supporting the free wire at least every 12
inches. Grommets where necessary. All relative motion between parts must
be stopped or one will eventually cut the other. Leave a nylon pull string
in place as well for possible future wire pulls.
Ted
Baker
Paul,
