[rebel-builders] Wing attach hole size - Moose
Ted Waltman
Post by Ted Waltman » Sun Feb 19, 2012 8:54 pm
Hello David,
I'll send you a copy of the 3500 mods "chapter 3 Fuselage Front Spar Attach
Fitting" document to your individual email address. FUS-712 is shown as
2"x2"x.120-128Wall 6061-T6.
Ted Waltman
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of davids
Sent: Wednesday, July 20, 2011 2:44 AM
Subject: [rebel-builders] Wing attach hole size - Moose
Hello
I am normally a lurker on this site, but have come upon a
problem and seek advice. In fitting the wing to the front
attach point, the manual calls for a 1/2" reamed hole, the
modification manual calls for a 1/2" hole and a bushing part
number W-712. Does anyone have final size dimensions and
materials spec for this bushing as there weren't any
bushings in the materials that I received. Holes were
previously drilled to 3/4" which makes sense for a bushing
and a 1/2" bolt, but of course there is ever present lack of
direction in the manuals.
Thanks & regards,
David Sproule
rhuzzey
Post by rhuzzey » Sun Feb 19, 2012 8:54 pm
Hi Ted
Could you send me that document as well.
I am never quite sure what I will run into building my Yukon as the manual was not completed.
Would be good to have infomation.
Reid
Sent from my iPad
On 2011-07-20, at 12:45 PM, "Ted Waltman" <ted@vafm.org> wrote:
Hello David,
Ted Waltman
Hello
Thanks & regards,
David Sproule
David Sproule
Post by David Sproule » Sun Feb 19, 2012 8:54 pm
Thank you Ted, this is very much appreciated.
Best regards,
David Sproule
Waltman
Sent: July-20-11 11:45 AM
Subject: RE: [rebel-builders] Wing attach hole size - Moose
Hello David,
Ted Waltman
Hello
Thanks & regards,
David Sproule
