[rebel-builders] Variations on control sticks
Jesse Jenks
Post by Jesse Jenks » Sun Feb 19, 2012 8:51 pm
Roland,
I cut my sticks so they go under the panel.
Subject: [rebel-builders] Variations on control sticks
Date: Wed, 6 Jul 2011 15:58:10 -0400
As my control sticks were hitting the panel before reaching the stop mounted
on the floor, I assumed that the sticks must have been modified with later
kits. Since I have seen a couple of Rebels on the net with sticks which have
a more pronounced bend rearward, I wrongly made the assumption that if I
ordered new ones from Darryl, I would get the revised ones. So the ones I
finally received were the same as the ones I had been given with kit #56.
Rule of thumb, ask twice, spend once. Obviously I didn't ask where these
"uber-bent" sticks came from.
Two questions, 1) does anyone else have the clearance problem between the
top of the stick and the panel? And 2) if there is plan to make modified
sticks or a source, can someone share the details?
Roland
R56
Post by Bob Patterson » Sun Feb 19, 2012 8:51 pm
Hi Roland !
I wouldn't worry about it ! The Rebel sticks have always touched
the panel - definitely DO NOT cut them shorter !! It will add to
control forces ...
Others have drilled a hole in the welded stop to fit 2 nuts & a bolt,
to make an adjustable stop - I think this was the original intent ...
When you come to adjust the cables, you can set it so the sticks
only touch in the corners if you want... All 4 of my Rebels touched ...
You will never need full forward anyway - that's why the majority have
elevators set to 27 to 30 degrees UP, and maybe 20 degrees or
less DOWN - you don't need a lot of down.... Even lifting the tail
on skis ! ;-)
bobp@prosumers.ca
bobp@pattersys.com
http://www.Pattersys.com
responsibility of the reader.
mounted on the floor, I assumed that the sticks must have been modified
with later kits. Since I have seen a couple of Rebels on the net with
sticks which have a more pronounced bend rearward, I wrongly made the
assumption that if I ordered new ones from Darryl, I would get the revised
ones. So the ones I finally received were the same as the ones I had been
given with kit #56. Rule of thumb, ask twice, spend once. Obviously I
didn't ask where these "uber-bent" sticks came from.
Roland
R56
Ron Shannon
Post by Ron Shannon » Sun Feb 19, 2012 8:51 pm
Me too. I cut them as much as I could and still have the RAC stick
grips fit on them. See http://n254mr.com/node/1406 . I think you'll
find that's what most people have done. My grips still hit the panel's
slanted side sections... but only in what would amount to a strong
bank, heavy dive condition that's highly unlikely to ever be used.
[Ed.: Hammerheads? <g>]
On Wed, Jul 6, 2011 at 1:38 PM, Jesse Jenks <jessejenks@hotmail.com> wrote:
Roland,
Post by Ken » Sun Feb 19, 2012 8:51 pm
The farther bent back sticks (about 5") were available from MAM for
rebels with the firewall moved back 3".
Roland
R56
