Mixer horn question
Mike Davis
Mixer horn question
Post by Mike Davis » Fri Feb 17, 2012 7:22 pm
Received: from d12lmsrelay.emea.ibm.com (d12lmsrelay.emea.ibm.com
[9.165.215.20])
by d06lmsgate.emea.ibm.com (1.0.0) with ESMTP id NAA43828
for <murphy-rebel@dcsol.com>; Wed, 21 Oct 1998 13:35:38 +0100
Received: from DE.IBM.COM (d12lms01.emea.ibm.com [9.165.215.18])
by d12lmsrelay.emea.ibm.com (8.8.7/8.8.7) with SMTP id MAA12428
for <murphy-rebel@dcsol.com>; Wed, 21 Oct 1998 12:48:51 GMT
Received: by DE.IBM.COM (Soft-Switch LMS 3.0) with snapi via D12AU005
id 5120010018151766; Wed, 21 Oct 1998 12:38:29 +0000
Subject: Mixer horn question
Message-ID: <5120010018151766000002L162*@MHS>
Date: Wed, 21 Oct 1998 12:38:29 +0000
MIME-Version: 1.0
Content-Type: text/plain; charset=iso-8859-1
Content-Transfer-Encoding: quoted-printable
Content-Disposition: inline
=0AHi,
there was a question left unanswered by Bob about the mixer horn.
(Bob, we got you on this one. Just kidding and thanks for the hint with=
Van's
as a resource for a baffle kit)
Stefan
This is MAM's answer from '96:
Hi, I've found that the mixer horn CC-48 is not symmetrical.
I try to "draw" it:
to torque tube
O
o o
+--> o ---- to control column
The bottom hole is not centered with regard to the
center bearing hole. How should the horn be mounted?
With the bottom hole closer to control column or away
from the control column?
Regards, Stefan.
Stefan,
You are correct in that the mixer horn is not symetical. But i=
f you
follow the instruction, you need to make the bottom hole and the pivot =
hole,
90 degrees to the push-pull tube. When you have done this correctly, t=
he
front hole will be higher than the rear hole.
Hope this helps.
Francis
Murphy Aircraft Mfg. Ltd.=
Mike Davis
Mixer horn question
Received: from [137.186.225.228] (helo=ms01-482.tor.istar.ca)
for murphy-rebel@dcsol.com
id 0zWAeg-0003a4-00; Wed, 21 Oct 1998 22:39:14 -0400
Mime-Version: 1.0
Subject: Re: Mixer horn question
Message-Id: <E0zWAeg-0003a4-00@mail2.toronto.istar.net>
Date: Wed, 21 Oct 1998 22:39:14 -0400
Thank you, Stefan !! I'm sure there are several builders who
appreciate
your answer !!
You DID 'get me' !! - I don't have all the answers (or even most of
them :-) ), .... just a poor 'sales guy' trying to help. You builders are
your own best resource - can't beat experience !!
--------------------------------orig.-------------------------------
At 12:38 PM 10/21/98 +0000, you wrote:
Hi,
Van's
Stefan
I try to "draw" it:
to torque tube
O
o o
Regards, Stefan.
Stefan,
You are correct in that the mixer horn is not symetical. But if
you
hole,
90 degrees to the push-pull tube. When you have done this correctly, the
Hope this helps.
Francis
