[rebel-builders] First Flight # 719
Ron Shannon
Post by Ron Shannon » Sun Feb 19, 2012 11:35 pm
Wahoo! No for the payback. Congralations!
254R
On Tue, Feb 1, 2011 at 1:46 PM, Rusty & Patti <aero30@coosahs.net> wrote:
Murphy Rebel N547A SER# 719 took to the air for first time . Liftoff at
about 600 ft on the grass, I held it down a little for the airspeed to come
alive,more on that later. Aircraft seems to levitate rather than rotate.
Clime rate seems normal for this power ,LYC O-235 and wing loading. Controls
are VERY light with little feedback but are not twitchy and no tendency to
over control. Very stable at cruise but seems to have neutral stability on
this short flight. All engine ops normal ranges. All pitot and static
instruments seem to wander quit a bit and could not be trusted so more
testing, and experimenting will be necessary. Landing was accomplished with
no problems at KPLR after 33min of flight with use of lift reserve indicator
for airspeed control . Many THANKS to ALL my aviation Buddies without which
this project would not have been so much fun. Many THANKS to the frequent
posters of REBEL BUILDERS whose experience kept the project rolling. Special
thanks to Cris who got this ad
venture started.
Video of first flight http://www.youtube.com/watch?v=6aQMkiaM8uI
Aircraft description
Lyc O235C1
Culver 74X46 Prop (too much pitch, Max RPM 2375)
Grumman Yankee exhaust (very Quite)
B&C 8amp alternator
sky tec starter (Dick Waters supplies)
Odyssey 680 Battery
UMA steam gages
Garmin 296GPS/Docket mount
Icom 210a comm
Lift Reserve Indicator (very handy when airspeed ind inop)
Firgelli electric flap actuator
Second and third flights not nearly so exicing. GREAT plane, FUN to fly.
Static system problem improved by sealing original static ports and
relocating 1/16th in. holes 2 in. from tip of STD MAM probe. Performance
tests ongoing, so far follow MAM data.
Keep on pulling those rivets Thanks
Rusty
N.Smith
Post by N.Smith » Sun Feb 19, 2012 11:35 pm
Result :o) Well Done !!!
Nig
745E
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Rusty
& Patti
Sent: 01 February 2011 21:47
Subject: [rebel-builders] First Flight # 719
venture started.
Lyc O235C1
B&C 8amp alternator
Odyssey 680 Battery
UMA steam gages
Icom 210a comm
Rusty
Post by Bob Patterson » Sun Feb 19, 2012 11:35 pm
Congratulations again !! Have fun ! :-)
I thought it sounded like it wasn't turning fast enough ....
you'll like it even more when you get a good prop !
bobp@prosumers.ca
bobp@pattersys.com
http://www.Pattersys.com
responsibility of the reader.
come alive,more on that later. Aircraft seems to levitate rather than
rotate. Clime rate seems normal for this power ,LYC O-235 and wing
loading. Controls are VERY light with little feedback but are not twitchy
and no tendency to over control. Very stable at cruise but seems to have
neutral stability on this short flight. All engine ops normal ranges. All
pitot and static instruments seem to wander quit a bit and could not be
trusted so more testing, and experimenting will be necessary. Landing was
accomplished with no problems at KPLR after 33min of flight with use of
lift reserve indicator for airspeed control . Many THANKS to ALL my
aviation Buddies without which this project would not have been so much
fun. Many THANKS to the frequent posters of REBEL BUILDERS whose
experience kept the project rolling. Special thanks to Cris who ! got this
ad
venture started.
Lyc O235C1
B&C 8amp alternator
Odyssey 680 Battery
UMA steam gages
Icom 210a comm
Rusty
Roland Kriening
Post by Roland Kriening » Sun Feb 19, 2012 11:35 pm
Congrats ! Another Murphy Grin :)
Shannon
Sent: Tuesday, February 01, 2011 4:51 PM
Subject: Re: [rebel-builders] First Flight # 719
254R
come
Controls
with
indicator
which
Special
venture started.
Lyc O235C1
B&C 8amp alternator
Odyssey 680 Battery
UMA steam gages
Icom 210a comm
Rusty
Jim Parr
Post by Jim Parr » Sun Feb 19, 2012 11:35 pm
Congrats Rusty!! Must have been a great feeling/ Gotta pull more rivets!
Sent: Tuesday, February 01, 2011 3:46 PM
got this ad
venture started.
Lyc O235C1
B&C 8amp alternator
Odyssey 680 Battery
UMA steam gages
Icom 210a comm
Rusty
Post by Wayne G. O'Shea » Sun Feb 19, 2012 11:35 pm
Like they say... you always remember your first !!!
Congrats!
Sent: Tuesday, February 01, 2011 7:10 PM
got this ad
venture started.
Lyc O235C1
B&C 8amp alternator
Odyssey 680 Battery
UMA steam gages
Icom 210a comm
Rusty
Eric Fogelin
Post by Eric Fogelin » Sun Feb 19, 2012 11:35 pm
Absolute congratulations. It is an awesome accomplishment. The transition
from being an aircraft builder to flyer is huge. It is a strange turn of
phrase to say that you are building an airplane to I'm flying an airplane
that I built.
Congratulations.
N645E
& Patti
Sent: Tuesday, February 01, 2011 1:47 PM
venture started.
Lyc O235C1
B&C 8amp alternator
Odyssey 680 Battery
UMA steam gages
Icom 210a comm
Rusty
Charlie Eubanks
Post by Charlie Eubanks » Sun Feb 19, 2012 11:35 pm
Congratulation Rusty
Really enjoyed your video. Now the fun begins.
I too am building an O-235 powered Rebel, #802R that is equipped a lot like
yours and I hope to fly it this summer. I know you are going to be busy with
phase I and don't want to interfere with your fun but if you get a chance, I
would like to hear what some of your numbers were, i.e. empty weight, CG,
performance numbers, battery location etc.
Charlie E.
charlie@troyairpark.com
636-462-2143
experience kept the project rolling. Special thanks to Cris who got this
ad
venture started.
Lyc O235C1
B&C 8amp alternator
Odyssey 680 Battery
UMA steam gages
Icom 210a comm
Rusty
rick greenwood
Post by rick greenwood » Sun Feb 19, 2012 11:35 pm
Congradulations Rusty,Cheers to many more flights.
Date: Tue, 1 Feb 2011 15:46:35 -0600
Murphy Rebel N547A SER# 719 took to the air for first time . Liftoff at about 600 ft on the grass, I held it down a little for the airspeed to come alive,more on that later. Aircraft seems to levitate rather than rotate. Clime rate seems normal for this power ,LYC O-235 and wing loading. Controls are VERY light with little feedback but are not twitchy and no tendency to over control. Very stable at cruise but seems to have neutral stability on this short flight. All engine ops normal ranges. All pitot and static instruments seem to wander quit a bit and could not be trusted so more testing, and experimenting will be necessary. Landing was accomplished with no problems at KPLR after 33min of flight with use of lift reserve indicator for airspeed control . Many THANKS to ALL my aviation Buddies without which this project would not have been so much fun. Many THANKS to the frequent posters of REBEL BUILDERS whose experience kept the project rolling. Special thanks to Cris who got this a
d
venture started.
Lyc O235C1
B&C 8amp alternator
Odyssey 680 Battery
UMA steam gages
Icom 210a comm
Second and third flights not nearly so exicing. GREAT plane, FUN to fly. Static system problem improved by sealing original static ports and relocating 1/16th in. holes 2 in. from tip of STD MAM probe. Performance tests ongoing, so far follow MAM data.
Rusty
