had their firewall loosening off etc that was also flying an O-360 on
straight floats out there in BC.
I've never checked to see whether the tubes are flexing, the rubbers or what
have you on mine. It's always been this way from the day I installed the
original O-235 to today with the O-320. 8 years later and it hasn't fallen
off or got any worse! Mine is a Conical mount! Is yours Conical or
Dynafocal??
Sent: Wednesday, November 26, 2003 10:44 PM
Subject: Re: engine mount
didHi Wayne I believe I called you about 4 1/2 years ago about firewall. I
,Ibeef up firewall with doublers or should I say stiffeners back to back on
top of firewall and doublers on mounts riveted too witches hat,doublers on
floor .Also put in float bars from overhead cage to firewall stiffeners. I
built my Rebel with .032 corner wraps from firewall back to baggage
dept..The only problem I have had is rivets in door hinge on cage smoking
Abouthave went up one size larger and longer and seems to be working fine.
backmotor mount when I mention the movement to the two AME I know they say it
should not move or flex like that so I always have that question in the
withof my mind that there is something wrong.A friend of mine with a Rebel
thea conical mount 0-320 engine does not move. THANKS jerry
Sent: Wednesday, November 26, 2003 6:51 PM
aboutDitto! I can move my motor up and down and at the spinner center I see5/8 movement. If it didn't move, something would break! (I could move
offirewallO-470 on my C182 around a lot more than that!!)
Jerry, wasn't it you that called me close to a year back about yourmoving around? and I suggested that you had too much "umph" on the nose
*-------------------------------------------------------------------------*arethat Rebel? Especially considering it didn't sound like you had any
reinforcement plates on the firewall. MAM's Elite style or "others" thatavailable.
Sent: Wednesday, November 26, 2003 9:46 PM
flexing.Jerry
Just out of curiosity do you know of any mounts that don't flex?
Where exactly is your mount flexing, and under what conditions is itGrant.
