If anyone could point me somewhere I would appreciate it. Thanks, CraigHas anyone messed with building wheel or penetration skiis for our rebel?
I built a set of skiis that I shamelessly copied from the avid flyer
webpage. Avid is gone but I think you should still be able to google some
pictures. My origional mount had the skis hinged below the axle but this
week I drilled the ends of the axles for a 3/8"pin and have plans to
rebuild my skis a bit wider and hinge on ends of the axle. I also have
moved the die spring attach point up above the axle to expose the inboard
end.
