[rebel-builders] Drilling through steel leaf springs: work-h
Bob Palmer
[rebel-builders] Drilling through steel leaf springs: work-hardenin
Post by Bob Palmer » Sun Feb 19, 2012 9:31 pm
I use a "Drill Doctor". They are pricey to buy but accurate and with a
little care you can sharpen to factory specs.
http://www.drilldoctor.com/pilot.asp
On 8/31/2010 5:30 AM, Ken wrote:
I've never found a drill sharpening jig that works very well so I just
sharpen them by hand on a bench grinder. The smaller ones sometimes take
a couple of tries to get them right. If one cutting edge is larger than
the other it might cut a tiny bit oversize so I do not usually sharpen
the #30 size when drilling rivet holes in aluminum but I certainly do
for drilling stainless. If they don't cut well just try again.
schaumr@dcsol.com wrote:
Thanks to all on the advice,
Got the job done with some overpriced "titanium" bits from the local hardware
store (said they were for stainless steel, so I thought they would be
adequate). Stepped up from 1/8, 1/4, 9/32, and finally 3/8" (on the drill
press)
Used 2-stroke oil as cutting fluid and stopped routinely to re-apply oil to the
work piece and/or change bit size. With the largest bit, I got the sense it
had to struggle more and started to sound like it was grinding again (no chips
being produced). It got through, but I'm not sure how the bit faired.
Regardless, it was educational. I like the idea of resharpening.... Ken.....does
one use a jig?
Rob
