Geeze Wayne, you really know how to make me feel stupid... I only asked for
$2 each!
oifa@irishfield.on.ca>
To: "Murphy Rebel Builders List" <
murphy-rebel@dcsol.com>
Sent: Monday, December 11, 2000 8:46 AM
Subject: 1st Push Pull Linkage off of Sticks
Geert is referring to the first push-pull tube coming off the control
column. MAM has you leave one rod end loose with no lock nut, so the steel
rod end is turning back and forth in the aluminum end plug (when moving the
stick for and aft). The "fix" for this is to take 2 small slices (about
3/16" to a 1/4" long) of 5/16 O.D. x 1/4 I.D tube and put one above and
below the rod end ball at the bellcrank end. This will allow the rod end to
swivel further without bottoming on the bellcrank or retainer washer, and
will also allow you to lock the other rod end with a nut. Not a PANIC item
for those that are flying, but it would be better to do it sooner than
tooooo much later!
Now as for that large Christmas Present Captain Geert proposed!!! Being the
pain I am to buy for at Christmas, the "wish" list I gave my wife lists a
Harvard (or a T-6) and a Spartan Executive, although I would be happy with a
firewall rearward kit for the SR3500 with extended fuel tanks. That's only
$26,995 + $170 for the extended tanks = $27,165 U.S divided by 169 list
members = only $160.74 U.S each!!!!!! Not a bad deal aye, and then I'll be
able to help the guys/gals building those too!!!!!!!!
I"M JUST KIDDING GUYS AND GALS! REALLY I AM!!!!!!
Blue skies,
BILNEWKIRK@aol.com
To:
Sent: Monday, December 11, 2000 11:34 AM
Subject: Re: from storch pilot
what bell-crank are you referring to?
Contributors' page at:
Visit the book store at:
List archives located at:
https://mail.dcsol.com/login
Unsubscribe:
List administrator:
mike.davis@dcsol.com
