Thanks Wayne I will check it out because I would have used whatever wasDrew.. it's a later kit. Has the top deck t rails spliced from when they
started throwing 5 x 14' 1500 float top deck rails into the last few kits
that went out the door before the recession.
If yours are wrong.. you'd have noticed... as the 22 fork ends use a 3/16
clevis pin.. not the 1/4" that the -32's do (and that came in the kit).
Worth checking though !
left in the box when I put mine together.
