[rebel-builders] control friction
Post by Ken » Sun Feb 19, 2012 6:19 pm
Don't get too picky. What seemed like a lot of friction during build
turned out to be a non issue in flight to me. With flaperons down things
definitely stiffen up but it is still not an issue at all.
I had to sand all the large delrin bearings quite a lot to get things as
loose as I wanted. I did not find that the Crown silicone made all that
much difference but you can spray it in through a #30 rivet hole and it
is worth trying. Unfortunately it may cause paint adhesion difficulty if
it runs outside the wing.
The other thing was that my tubes were not perfectly round. Massaging
them gently in a vice seemed to help a little. Any chance you can remove
the end horn to see if the binding is from too thick of a 2" washer?
Probably not likely but we can hope. Opening the wing would be a pain.
For the control column you may find that the brackets are simply out of
alignment.
Ron Shannon wrote:
Turns out things are not as rosy as it seemed, and it's time for the next
two (4, 6...?) steps back. When I got the control column fully reinstalled
yesterday (first time in a couple years) I found way too much friction in
both aileron and elevator.
Some disassembly to isolate the aileron/roll problem shows the right wing is
fine. However, the left wing torque tube, which has always been stiff, is
worse, so much so that the flaperon, once raised, will not fall on its own.
(It's fine when disconnected from the push-pull -- no friction in the
hinges.) There's even an audible squeal coming from inside the wing,
presumably the Delrin bearings. I've read recommendations of using (only)
the Crown silicone lube in the archives but, even after cutting an access
port to reach the wing torque tube bearings, I'm not sure I could apply it
where it needs to go, or if it would do the job.
Even with both wing torque tube horns disconnected at the wing roots, there
is still too much friction in the overhead torque tubes at the torque tube
hanger, quite a bit more than I remember from when it was last hooked up to
the column two + years ago. The SS AIL-26 bearings which butt up against the
hanger are not moving, which is correct, I think...? I'm wondering if the
(captive, unreachable) connecting bolt across the hanger may be too tight?
Accommodating the angle change there has been a plague for many, I know.
The essence of difficulty in solving the roll problems is I have two places
with too much friction, and neither is easily accessible. I sure hope I can
fix both the aileron/roll issues without having to pull the left wing off.
Too much elevator friction in the control column bearings too, but at least
there is access to that.
Experience suggests this stuff will turn out to be not as difficult as I
imagine now, but it certainly is discouraging. Suggestions appreciated.
254R
Ron Shannon
Post by Ron Shannon » Sun Feb 19, 2012 6:19 pm
Thanks, Ken, I appreciate the encouragement. Unfortunately, the friction is
enough I have concerns about even passing inspection -- just when I was
starting to anticipate it, no less. Tonight I'll hook things back up and try
to measure the forces.
On Wed, Apr 21, 2010 at 2:49 PM, Ken <klehman@albedo.net> wrote:
alignment.
Post by Walter Klatt » Sun Feb 19, 2012 6:19 pm
Ron, when you last assembled it, the outside temps might have been warmer.
Mine will stiffen up a bit in cold weather, but are perfectly fine above
freezing. I found this out last year, when I did some colder higher altitude
flying (about -8C), and I found both the elevator and flaperon controls were
stiff. When I got down to lower altitudes, they were fine again.
So, in your case, if they are stiff at above freezing, they might be worse
when colder.
With the elevator, I still remember when building that if I tightened the
rear pillow blocks down too tight, it also stiffened up the elevator
controls.
Have never tried that Crown lubricant, but have heard it mentioned here
before, too.
Shannon
Sent: Wednesday, April 21, 2010 3:00 PM
Subject: Re: [rebel-builders] control friction
alignment.
snowyrvr@mtaonline.net
Post by snowyrvr@mtaonline.net » Sun Feb 19, 2012 6:19 pm
If it makes you feel any better, my control stick bearings are fine but my
elevator horn is kind of stiff, no matter what order I torque the blocks
in. I'm thinking the floor they bolt to is so thin that they can torque it
enough to cause drag. I might consider it a poor man's auto pilot but for
you...you probably have a real one installed already!
Original Message:
Date: Wed, 21 Apr 2010 12:13:22 -0700
Subject: [rebel-builders] control friction
254R
myhosting.com - Premium Microsoft
Ron Shannon
I wish I was just being picky, but at present, I'd be reluctant to fly the
aileron function myself, much less have to explain the squeal to an
inspector. I've thought hooking up some electro-mechanical device to
exercise the flaperons up and down around the clock to see if it might
eventually break in. :-/
Funny you'd mention the A/P though, because I do have a TruTrak Digiflight
II VSGV head in the panel and servo wires are deployed, but I don't intend
to mount the servos until later. The one advantage I've thought of to maybe
having to cut a big access port in the wing is that maybe then I could mount
the roll servo out there too, instead of tying it into the first bell crank
-- where I'll probably mount it, later on. Lest there be any confusion, it's
not mounted now so can't be any part of the problem.
Thanks for all comments. I'll try to measure forces tonight. Gotta keep
mowing right now. There's quite a bit to do here. It's that time of year
when the grass grows about 3/4" per day. Lots of time to think about this
while riding the mower.
On Wed, Apr 21, 2010 at 4:37 PM, snowyrvr@mtaonline.net <
Original Message:
is
254R
myhosting.com - Premium MicrosoftŽ WindowsŽ and Linux web and application
hosting - http://link.myhosting.com/myhosting
Personally I would not care to have a motor exercise a 0.035" thin
walled aluminum tube in the hope of wearing anything down...
Ahh you're probably kidding anyway...
Have you seen the discussion in the archives about running an angle (I
used a piece or stringer material) left to right across the shelf (just
behind the bearings) that the elevator horn mounts on. That reduces
flexing and binding. Any tension in the elevator cables wants to flex
that shelf down and bind the bearings. The piece of stringer stops the
flexing.
Thanks, Ken for reminding me of that. It's on my list (which is much, much
longer than Ron's):)
Original Message:
Date: Wed, 21 Apr 2010 20:49:57 -0400
flexing.
it
Eric Fogelin
Post by Eric Fogelin » Sun Feb 19, 2012 6:19 pm
Hey Ron.
Try loosening all of the bolts that hold the delrin bearings in place and
let them find their natural location. Study what needs to be done and shim
using half washers as needed. A couple/few thin shims may take care of your
problem.
N645E
Shannon
alignment.
Ron Shannon
Eric, that may help with the right control column (elevator) bearing, where
I have put in floor brackets to make the control column removable, but
friction in the left wing internal torque tube bearings is the main problem,
and of course, I can't get at them without cutting some significant holes.
It may come to that eventually, but I'll try to get some of the Crown
silicone lube on them, and anything else I can think of, before doing major
surgery.
I have now measured aileron (roll) friction as follows, in both cases using
a digital fishing gauge pulling at the top of the (shortened) stick with no
grip, at approx. 12.5" above the stick pivot:
1) With both wings disconnected at the wing root torque tube horns, friction
in just the inside torque tube setup averages roughly 1 lb. 2 oz., and
increases slightly out near the stops. There is no appreciable friction in
the inside push pull tube bearings or bell cranks, so the great majority of
that is probably at the hanger bolt and possibly a little in the guide
pin/bolts, which are still inserted in the wings, of course. Not good.
2) With both wings connected via their respective wing root torque tube
horns, the friction averages about 3 lb. 6 oz. for right aileron (left
aileron falling) and about 4 lb. for left aileron (left aileron rising).
These numbers are probably not real precise, but are certainly in the ball
park of repeatable scientific data, and certainly not good. The "squeal"
from the left wing torque tube bearings seems to come randomly from either
or both bearings, though always on the flaperon down motion and none on the
upward motion.
Again, to repeat, there is no significant friction in the right wing, and
the left wing flaperon hinges are free and quiet when tested alone with the
flaperon push pull disconnected, so the left flaperon hinges are not
contributing. The left wing torque tube bearings are stiff by themselves,
i.e., when disconnected from the fuse, etc. The spacers at the wing root
horns seem to fit well, so I don't think they are contributing to any
binding by spreading the horns apart or pulling them together out of their
natural positions.
I'm going to proceed incrementally, trying to lube places I can get to
first, like the guide pin bolts and hanger bolt -- to the extent I can get
something in the latter. Suggestions? Then will try to find some of the
Crown silicone lube and find some way(s) to get it to the left wing torque
tube bearings.
Does anyone know where I can get single cans of the Crown silicone lube? All
I've found so far are 12-can case lots, at $70-80 ea. Thanks.
254R
On Wed, Apr 21, 2010 at 9:40 PM, Eric Fogelin <elist@whidbey.com> wrote:
Hey Ron.
problem.
N645E
Ron Shannon
Eric -- After re-reading your suggestion a little closer, I realize you're
proposing adjustments to the bolts mounting the Delrin bearings themselves,
not just alignment of the brackets. I'll give that a go for the elevator
problem. Thanks.
Progress -- I put some Corrosion-X at the hanger bolt and guide pin bolts.
(I well know this stuff makes painting anything within 100 yds. downwind
impossible for years, but it is a helluva penetrating lubricant... so I
taped paper towels underneath to catch drips.) Lacking a plastic mini-straw
for the spray can, I sprayed a bit into a tuna can (outdoors!) and used a
Q-tip to jam some drops onto the guide pin bolts and into the small space
above the left hanger bolt AIL-26. Clearance was too small to get on the
right side AIL-26 so I got some on the top side of the hanger itself knowing
it will drip down.... all the while working the stick back and forth.
Results are promising. Left stick force has been reduced by about 12 oz.,
down from 4 lb. to an average of 3 lb. 4 oz., so I may have taken out a good
chunk (~2/3) of the friction at the hanger bolt already. As the C-X migrates
further into the joints there -- which is what it does best -- that may
improve even more. There's still something on the order of 3 lbs. and the
squeal in the left wing though.
Ken (and others) -- What aileron stick force could be considered normal,
expected and/or OK? 3 lbs. feels like way too much, but if I make some more
progress I'd like to have a clue when I might possibly be getting picky. :)
You're quite right to raise that possibility, of course, as I'm quite
capable of -- in fact, expert at -- over-thinking, over-worrying and
over-obsessing about this project -- simultaneously! ;)
PS - No, I don't think C-X would be good for Delrin.
Hey Ron.
problem.
N645E
Dale Kilbey
Post by Dale Kilbey » Sun Feb 19, 2012 6:19 pm
I had a problem with one wing. I loosened all the bolts holding the delrin
bearings with no apparent effect. I didn't have any crown lubricant but I
had a can of Rustcheck. One squirt and no more friction.
Dale
Sent: Thursday, April 22, 2010 2:13 AM
where
problem,
major
surgery.
using
no
friction
upward motion.
natural positions.
tube bearings.
All
254R
Hey Ron.
shim
your
problem.
N645E
Ron Shannon
Thanks, Dale. After poking around a bit, that looks like another great
Canadian product that's hard to find in the 2nd world neighbor to the south,
but I will keep looking. ;)
On Thu, Apr 22, 2010 at 9:05 AM, Dale Kilbey <dale.kilbey@persona.ca> wrote:
Dale
Ron Shannon
The Corrosion-X applied at the hanger and guide pins last night has had
several hours to migrate now, and it seems like maybe there's been a little
more reduction in the flaperon (roll) control friction.
I was going to put off cutting the 1" flaperon hinge inspection holes in the
bottom wing skin, but it seems they would probably provide a decent angle to
spray something toward the torque tube bearings in the wing, so I'm going to
cut those holes now instead of later.
I haven't found a source for single cans of the Crown silicone lube and will
probably just go ahead and buy a 12-can case. I could sell the extra single
cans to any other builders who might be interested, at my cost plus
shipping, which I'm guessing would be around $15 total for US addresses. If
you might be interested in getting a can, please let me know off list by
direct email. Thanks.
254R
Post by Wayne G. O'Shea » Sun Feb 19, 2012 6:19 pm
I have a couple cases here Ron.. but don't think I can ship an aerosol can
to the USA in the mail anymore...
where
problem,
major
surgery.
using
no
friction
upward motion.
natural positions.
tube bearings.
All
254R
Hey Ron.
shim
your
problem.
N645E
