Gents,
Hope someone can point me in the right direction.
I'm a new Rebel ESN 249R owner. Original builder passed away.
Are the build manuals available in soft format. In particular I'm looking for Murphy float installation . Any other manuals would be greatly appreciated.
Carl
To: rebel-builders@dcsol.com <rebel-builders@dcsol.com>
Sent: Mon Apr 19 02:27:40 2010
Subject: [rebel-builders] 254R - report from the trenches
For those who don't follow my web site on a daily basis [both of you] these
are the last nine (!) "build / install" items left to do before inspection
-- cut & pasted from the task spreadsheet. The numbers on the left are the
approx. percentage of each item that's already been completed.
20 Brake plumbing 50 Re-install control column 40 Install/wire stick
grips 30 COM 1 antenna install 50 XPNDR antenna install 10 Baggage rear
wall
Rudder tip 80 Placards
Install seat belts
In addition there are things already built which will need to be reassembled
(fairings, cowl, hook up cables, etc.) and lots of "operational /
administrative" items, like change the pickle oil for break-in oil, fuel
line & flow tests, engine start & tune (next week, I hope), static test,
W&B, etc.
Jim started the project in 1996. I've had it four years and one month. At
this stage, the drudgery has disappeared, and the fun factor is very high.
http://n254mr.com
PS - Most of the above is true. :)
Disclaimer/Avertissement
This email and any files transmitted with it are privileged, confidential, and intended solely for the use of the individual or entity to whom they are addressed. Views expressed are those of the author and not necessarily those of the Corporation or its affiliates. Any unauthorized use or disclosure is prohibited. Please notify the sender if you have received this email in error. Thank you for your co-operation.
Le présent courriel et, s'il y a lieu, ses pièces jointes constituent des renseignements confidentiels et destinés au seul usage de leurs destinataires, qu'il s'agisse de particuliers ou d'organismes. Les opinions qui y sont exprimées sont celles de l'auteur et ne correspondent pas nécessairement à celles de la société ou de ses affiliées. Il est interdit d'utiliser ou de divulguer ces renseignements sans autorisation. Si vous avez reçu ce courriel par erreur, veuillez communiquer avec son expéditeur. Nous vous remercions de votre collaboration.
[rebel-builders] Rebel build Manual
snowyrvr@mtaonline.net
Hi Carl! Welcome to the group. I was able to buy a manual from Murphy.
You might give that a try. Craig
Original Message:
Date: Mon, 19 Apr 2010 06:09:29 -0400
Subject: Re: [rebel-builders] Rebel build Manual
Gents,
appreciated.
Carl
wall
Install seat belts
W&B, etc.
http://n254mr.com
mail2web.com - Microsoft
Original Message:
Gents,
appreciated.
Carl
wall
Install seat belts
W&B, etc.
http://n254mr.com
