Date: Thu, 21 Jan 2010 04:00:20 -0800
im_planecrazy@yahoo.com
Subject: RE: [rebel-builders] Lord mount bolt length
To:
rebel-builders@dcsol.com
Are you using the CD instead of the manual? I need to get my butt back in
gear one of these days and get back to work on my Rebel. I had thought I
read that Wayne was going to produce a CD for a Rebel build as he did for
the floats. But never read anything more about it. Maybe I am mistaken.
He has fixed/built enough of them I am sure his tips and upgrades would
be included and might make the build process less of a head scratching
affair for us first time builders. But then maybe it was all a dream.;0
Keith R661
--- On Wed, 1/20/10, Jesse Jenks <
To: "Builders list" <
rebel-builders@dcsol.com>
Date: Wednesday, January 20, 2010, 10:15 PM
Thanks Craig,
These days I refer to the manual so infrequently that I sometimes forget
it even exists. In this case I want to use genuine Lord mounts because
they are supposedly better, offer more dampening etc. I believe the part
# from the manual is actually a Barry part # even though MAM says Lord. I
called Lord and was given the J7402-24 part # to fit the dynafocal mount
with 1 3/8" diameter holes. I suppose that if I can't come up with the
bolt to match these mounts then the one you quote from MAM would at least
be a place to start.
snowyrvr@mtaonline.net
To:
Subject: Re: [rebel-builders] Lord mount bolt length
Date: Wed, 20 Jan 2010 18:30:44 -0900
Hi Jesse!
This excerpt is right out of my CD manual in the 0320 eng install
chapter:
0320 LYCOMING ENGINE INSTALLATION 29/04/98
34 - 6
7) Support the engine however you like as long as it will move without
chance of dropping
it. Attach the engine mount to the engine with four Lord Mounts
(94150-40),
four AN7-35A
bolts, eight AN970-716 washers and four AN363-720 locknuts.
It then follows with a "spiffy" full color diagram supporting the
statement.
But as Ron says, don't forget the F.R.R.B! Craig
Sent: Wednesday, January 20, 2010 1:38 PM
Subject: [rebel-builders] Lord mount bolt length
List archives located at:
https://mail.dcsol.com/login
Unsubscribe:
List administrator:
mike.davis@dcsol.com
Your E-mail and More On-the-Go. Get Windows Live Hotmail Free.
http://clk.atdmt.com/GBL/go/196390709/direct/01/
Unsubscribe:
List administrator:
Unsubscribe:
List administrator:
