On 12/29/2009 3:13 PM,
trailriver@hotmail.com wrote to rebel-builders:
-> Hi Bob, if you are going to put a spring gear on a Rebel, you will need
to beef up the mounting area so it can withstand forces of a spring gear. I
know, it happened to me. The square tubing cracked around one for the
mounting bolts. I did the modification and it works great. I have some
extra material as I had to buy a full length of it. I can sell you the
material or cut and machine it for you. It is time consuming.
-> Russ
-> > From:
charlie@troyairpark.com
-> > To:
rebel-builders@dcsol.com
-> > Subject: Re: [rebel-builders] spring gear
-> > Date: Tue, 29 Dec 2009 08:45:24 -0600
-> > Bob
-> > If you are talking about a Die Spring gear you need to talk to Wayne G.
-> > O'Sshea oifa@irshfield
-> > CharlieE. 802R
-> > From: "The Halls" <
rdhall@xplornet.com>
-> > To: <
rebel-builders@dcsol.com>
-> > Sent: Tuesday, December 29, 2009 6:10 AM
-> > Subject: [rebel-builders] spring gear
-> > > Hi , Does anyone out there know where to get a spring landing gear
-> > > assembly for a rebel. Thanks Bob
-> > > List archives located at:
https://mail.dcsol.com/login
-> > > username "rebel" password "builder"
-> > > Unsubscribe:
-> > > List administrator:
mike.davis@dcsol.com
-> > List archives located at:
-> > Unsubscribe:
-> > List administrator:
-> _________________________________________________________________
-> Hotmail: Powerful Free email with security by Microsoft.
http://clk.atdmt.com/GBL/go/171222986/direct/01/
Hi Russ,
I'm building 818R down here in OZ and am approaching the spring gear
part. I've been thinking about beef ups as it seems there have been some
problems. What material do you have? I've been supplied with some aluminium
angle to rivet to the FUS 5, is that what you have?I've also thought a
thicker wall FUS 5 would help,if available, possibly with another tube or
bar nested inside for a foot or so in from the ends. Was it the front FUS 5
that cracked in your plane?
Cheers Mike
Unsubscribe:
List administrator:
