[rebel-builders] Tie down ring
Post by Wayne G. O'Shea » Sun Feb 19, 2012 8:46 pm
These are the ones I use.
http://www.bosunsupplies.com/products2. ... duct=S0322
Sent: Thursday, November 12, 2009 12:25 PM
Subject: Re: [rebel-builders] Sealing Tank
Jones, Michael wrote:
If you did not use those rings, what did you use
Mike jones
snip
I used a stainless
female marine eye on a grade 5 bolt.
Mike I believe I purchased them from Westcoast Marine. They screw on the
end of a bolt and take the place of a nut.
skytrucks
Post by skytrucks » Sun Feb 19, 2012 8:46 pm
Wayne, Those rings look good, what size should I buy for my Moose?
Thanks;
Larry Luckinbill
117 Moose
Sent: Thu, Nov 12, 2009 10:31 am
Subject: Re: [rebel-builders] Tie down ring
rom: "Ken" <klehman@albedo.net>
Mike jones
snip
I used a stainless
Jeff Micheal
Post by Jeff Micheal » Sun Feb 19, 2012 8:46 pm
Hi Larry,
Since the strut fittings are secured with AN4 bolts (1/4") then I would
recommend part # S0322-0007. If you like to use the next size larger, part
# S0322-0008 (5/16"), this can be done simply by increasing the hole
diameter where you are going to install the tie down ring. Up sizing bolt
hole from 1/4" to 5/16" is a non-issue.
Jeff
Thanks;
Larry Luckinbill
117 Moose
Mike jones
snip
I used a stainless
Joel Jacobs
Post by Joel Jacobs » Sun Feb 19, 2012 8:46 pm
Also notice the 1/4 and 5/16 eyes are the same dimensions except for
the threaded hole. I bet you could re-tap the 1/4" one to 5/16 NF and
use a real AN bolt.
Joel
On Thu, Nov 12, 2009 at 4:33 PM, Jeff Micheal
<westcoastkitplanes@gmail.com> wrote:
[quote]Hi Larry,
