[rebel-builders] Sika Flex
Post by Wayne G. O'Shea » Sun Feb 19, 2012 8:41 pm
I've just finished repairing a set of 1800 Amphib floats that I originally
built in 1996.... with Sikaflex 1A. They've never leaked a drop in their
lift time (well up until a little 100 MPH landing on the water opened up a
compartment a couple years ago) and they aren't gonna leak again (unless
someone lands the same way again)
1A is about the only variant that gives the 6 or 7 hours work time that you
need to get a side skin riveted on by yourself, and still be able to fillet
the seams with a popcycle stick.
Jason.. I use limestone (because that is usually in stock for the stone
masons) and sometimes gray/aluminum if I need to order it in. Both colours
hide well. I get mine through United Rental.
To: "Rebel Builders" <rebel-builders@dcsol.com>
Sent: Thursday, October 29, 2009 9:05 AM
Subject: [rebel-builders] Sika Flex
Not to throw a wrench in things, but I (and many of the RV-10 folks)
used Sika Flex 292UV black ($18.99 per tube) along with Sika 209
primer ($50.99 per bottle). They make other variants, but this has
the UV protection and seemed to be best for the application..... I
got mine from Jamestown Distributers in the US...
-Mike Kraus
RV-4 Flying
RV-10 finishing
Moose on deck
Sent from my iPhone
Rebecca Brownell
Post by Rebecca Brownell » Sun Feb 19, 2012 8:41 pm
Thanks wayne!Looks like I'll be doing the test flight on the amphibs.
Jason
817R
originally
their
opened up a
(unless
that you
fillet
stone
colours
-Mike Kraus
RV-4 Flying
RV-10 finishing
Moose on deck
Sent from my iPhone
