Hello, we are just starting to put on our cowl for the moose with the radial engine and realize there is no instructions for this and would like any input, help or suggestions that others have run into for this. thanking you in advance Michael Bleau
New! Get to Messenger faster: Sign-in here now!
http://go.microsoft.com/?linkid=9677407
[rebel-builders] Moose cowl
Hi Michael,
Did you get the instruction sheets with photos from MAM with your cowl? If not, I will fax you copies of mine. I will say, however, that it was a bit difficult to visualize at first. I also looked at the goflyamoose.com site to compare pics and see what he did with his cowl. I had never worked with fiberglass before, so while I am pleased well enough at this point, it certainly won't win any awards. If you'd like the fax, you can send the number to my e-mail.
Darryl SR169
Sent: Thursday, September 17, 2009 2:05:02 PM
Subject: RE: [rebel-builders] Moose cowl
Darryl SR169
Hi Michael,
I have a copy of the M14 Cowl installation. I'll send it via email directly
to you when I get home..... in about a few hours.
Jeff
On Thu, Sep 17, 2009 at 11:05 AM, Michael Bleau <bleaumichael@hotmail.com>wrote:
Jeff
Hi Michael,
I have a copy of the M14 cowl install. I can send it to you via email when
I get home.......... a few hours from now.
Jeff
(Chilliwack, BC)
Jeff
(Chilliwack, BC)
I can email folks many detailed pictures of my cowling (pretty stock w/ few
mods) or details of other folks cowlings if desired. Send me an email if
you want pictures: tedwaltman@gmail.com
Ted
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Darryl
Conway
Sent: Thursday, September 17, 2009 7:24 PM
Subject: Re: [rebel-builders] Moose cowl
Hi Michael,
Darryl SR169
Ted
Conway
Hi Michael,
Darryl SR169
Hi Ted !
Anything like those pictures will definitely be of long-term
use to many builders. If you can post even a few to the FILES section,
I'm sure it would be much appreciated .....
Mike has provided us with a great platform to share knowledge.
We should use it to full advantage !
Thanks !!
PS - If anyone has the actual instructions & sketches, they could
go in the General Documentation section (or Cowling).... It would
be a big help for all builders !
bobp@prosumers.ca
responsibility of the reader.
Thanks !!
bobp@prosumers.ca
few mods) or details of other folks cowlings if desired. Send me an email
if you want pictures: tedwaltman@gmail.com
Ted
Darryl Conway
Hi Michael,
Darryl SR169
I'll put together a collection of pictures and post to the list this weekend
(hopefully).
Ted
Patterson
Sent: Friday, September 18, 2009 8:31 AM
Hi Ted !
Thanks !!
bobp@prosumers.ca
(hopefully).
Ted
Patterson
Hi Ted !
Thanks !!
bobp@prosumers.ca
Ted
Darryl Conway
Hi Michael,
Darryl SR169
