Spinners
spinners
Post by Wayne G. O'Shea » Sat Feb 18, 2012 10:16 am
Well I did.....until you gave out their phone # direct ...since they don't
advertise for retail sales and they let us "dealers" take care of things for
them! Thanks, I'm trying to downsize anyhow I guess! Wayne
From: "british thunder" <britishthunder@sympatico.ca>
Sent: Thursday, March 10, 2005 7:54 AM
Subject: Re: spinners
Clay
Not sure where you are, but I have had good luck getting spinners from
UHS.
They are fibreglass and usually ships the next day balanced and all
hardware
included.
905534
I think Wayne sells them as well.
Sent: Wednesday, March 09, 2005 8:53 AM
Subject: spinners
Clay,
If you are using the "speed cowl" it seems to me that any spinner that
leaves a gap between the spinner edge to the cowl intake will require
the air passing down the side of the spinner to "bounce" off the flat
face of the cowl creating turbulence at the intakes and restricting the
flow of incoming air. On our speed cowl that requires a full 13"
diameter.
We elected to go with the Van's fiberglass spinner for ease of
installation. You can see exactly where to drill and the bulkheads are
fitted to the Sensenich prop thickness.
Rebecca Brownell
spinners
Post by Rebecca Brownell » Sun Feb 19, 2012 5:29 pm
Hi all
Trying to figure out my spinner options here.Are those UCS spinners
from spruce any good?Does one usually order them pre cut ?
Thanks,Jason
817R
