Looking for Rebel to fly to Alaska in loose formation, any one out there would be interested to join?
Jay N654JM
www.chinesepilots.com
Get back to school stuff for them and cashback for you.
http://www.bing.com/cashback?form=MSHYC ... shback_1x1
[rebel-builders] Over size tires
At 08:04 AM 13/08/2009 -0700, you wrote:
considering 8.50 x 6, or larger, any one out there can shine me some lights?
no issues. Which wheels do you have? I had to add spacers to silver Matco
ones when I switched to 8:00's
Alaska in Mid September, like to switch to larger size tires, I'mAny Rebel out there has tires larger than 8.00 x 6, I'm planning a trip to
Hi Jay Angus McKenzie had 8:50's on his plane when it was on wheels with
Hi Drew,
I have 6" wheel on spring gear, what kind of landing gear Angus has?
Jay
Get your vacation photos on your phone!
http://windowsliveformobile.com/en-us/p ... =0809TL-HM
Jay
_________________________________________________________________Date: Thu, 13 Aug 2009 12:11:01 -0400
Subject: Re: [rebel-builders] Over size tires
At 08:04 AM 13/08/2009 -0700, you wrote:Alaska in Mid September, like to switch to larger size tires, I'mAny Rebel out there has tires larger than 8.00 x 6, I'm planning a trip to
considering 8.50 x 6, or larger, any one out there can shine me some lights?Hi Jay Angus McKenzie had 8:50's on his plane when it was on wheels with
At 09:59 AM 13/08/2009 -0700, you wrote:
that MAM has shipped over the years some are better than others.
Angus had bungee gear on his plane. There's a bunch of different 6" wheelsHi Drew,
Jay
I wonder if the spring gear is strong enough for those tires (8.50 x 6)? Thanks for the info. I guess I need to find out the width of the wheel before I purchase one.
Jay
Express your personality in color! Preview and select themes for Hotmail
Jay
_________________________________________________________________Date: Thu, 13 Aug 2009 13:10:53 -0400
Subject: RE: [rebel-builders] Over size tires
At 09:59 AM 13/08/2009 -0700, you wrote:Angus had bungee gear on his plane. There's a bunch of different 6" wheelsHi Drew,
Jay
Do you have Air Track 8.00x6 tires? I may face the same problem then.
Jay
Get free photo software from Windows Live
http://www.windowslive.com/online/photo ... are:082009
Jay
_________________________________________________________________From: rebaker@sc.rr.com
Subject: [rebel-builders] Over size tires
Date: Thu, 13 Aug 2009 15:04:40 -0400
We have 8:00 -6 on our Elite as a MAM upgrade and there is only a hairs breadth of room from the tire to the caliper. That after MAM supplied new calipers as the originals were interfering. I looked at spacing them out but the longer AN3 bolts required were about US$8.00 each at the time plus having to make the spacers.
Pleased you recall that fact Drew, 8:50x6 McCreary Air-Trac's. Had some
probs with
proper tube valve stem angle/shape, ended up using a long braided stainless
valve stem extender that routes to the proper outlet hole.
No figures but they slow you down.
Wheels are made by Murphy and are standard 6" with no mods to brakes or
anything. Other than removal of all plastic lines and installation of alum.
and braided stainless from your feet to the calipers. Much more positive.
Did machine the axle ends to insure 1 degree toe-in of wheel alignment for
obvious reasons.
My old 6 x 9044 rings ea.side bungee gear is on FINR now and when the floats
come
off next for service I've got new die spring gear to install.
Sent: Thursday, August 13, 2009 12:11 PM
probs with
obvious reasons.
come
