[rebel-builders] Renegade Spirit Shock Rings
peter gibbs
Post by peter gibbs » Sun Feb 19, 2012 5:24 pm
Hi Nigel,
the standard Renegade undercarriage uses a long bungee that has to be
stetched and lashed at every turn, its a real finger bender, Rgds Peter
Gibbs G -CBFK
Sent: Wednesday, April 29, 2009 9:15 AM
Subject: [rebel-builders] Renegade Spirit Shock Rings
Hi All
Anyone got an idea which shock rings the Renegade Spirit uses (I think for
the undercarriage)
Nig
745E
Post by Bob Patterson » Sun Feb 19, 2012 5:24 pm
Hi Nig !
If the bolts are the same spacing as the Rebel - which I believe
they are .... we've been using stock 9044 rings for years. MUCH
easier than trying to pull that long piece of bungee around !!
These 9044's are stock for Piper products - 9/16" thick, and 4.4"
ID. We use 2 per side, each, front & back, for a total of 8, for
lighter Rebels, and add one more on top of the others for heavier
Rebels - a total of 12. They are available from Aircraft Spruce,
and others - pays to shop, as prices vary widely !
The trick is to put one over the top bolt, inside the penny
washer, then hook a 'come-along', or nylon cargo strap with
a ratchet, to the bottom end. The other end of the strap
goes to the bottom of the gear leg tube. Just ratchet until
the bungee is past the bottom bolt, and use a large screwdriver
to lever it onto the bolt. Top bolt faces rear, bottom bolt front ...
Or .... you can just buy a length of 1/2" bungee & try
to wrestle it around the bolts, tightening after each wrap.
It is difficult & dangerous, and usually loosens after a few
landings, necessitating re-tensioning .... :-(
bobp@prosumers.ca
http://www.PattersonAeroSales.com
On Wednesday 29 April 2009 08:15, N.Smith wrote:
Hi All
the undercarriage)
Nig
745E
Post by Wayne G. O'Shea » Sun Feb 19, 2012 5:24 pm
Or Nig.. your friend in France... that emailed me 3 weeks back.. could have
responded to the email and pics I sent him for die spring struts for it!
Sent: Wednesday, April 29, 2009 10:04 AM
Subject: Re: [rebel-builders] Renegade Spirit Shock Rings
Hi Nig !
bobp@prosumers.ca
Hi All
for
the undercarriage)
Nig
745E
N.Smith
Post by N.Smith » Sun Feb 19, 2012 5:24 pm
Thanks Peter and others who replied.
It was to answer a question I'd had from a restorer in Spain. Think we've
got it sorted now.
Thanks again to all
Nig
745E
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of peter
gibbs
Sent: 29 April 2009 09:41
Hi Nigel,
Gibbs G -CBFK
Hi All
the undercarriage)
Nig
745E
Checked by AVG - www.avg.com
Version: 8.5.287 / Virus Database: 270.12.7/2085 - Release Date: 04/28/09
18:02:00
