[rebel-builders] Dimentions-dash
Post by Ken » Sun Feb 19, 2012 5:07 pm
Jason
I don't have dimensions but I can tell you that I do seem to recall
extending the brackets on the firewall out a couple of inches aft to
make the angles work. I assume you did cut back the side panels of the
instrument panel to pull the panel rearwards.
I believe I also changed the angle the tubes meet the instrument panel
at a tiny bit. I already had a very strong channel with reinforced
corners under the panel otherwise that might not be a good idea.
Rebecca Brownell wrote:
Hi all
I need to double check some measurements.I'm installing the dash
braces and they aren't lining up just right.
I moved the firewall back as per manual and wanted to know the
distance from the face of the pannel to the firewall,
or from the rear edge of the upright's on the cage to the face of the
pannel.The problem is the angle of the bends in the dash
pannel have changed when shortening and the braces don"t meet in the
middle of the firewall.If someone wouldn't mind checking those
dimensions for me it would tell me what the heck is going
under there.
Appreciate the help
Jason
817R
Rebecca Brownell
Post by Rebecca Brownell » Sun Feb 19, 2012 5:07 pm
Thanks Ken
I did trim the panel back as well which keeps the same space behind
the panel.I was thinking that I could do what you seem to have done
in changing the angle a bit and reinforcing the corner of the
panel.just wasn't sure if this was acceptable or not.The braces are
more to stiffen
the panel than the firewall isn't it?It's not a huge correction,I'd
say 4 or 5 degrees.Do you think I'm OK to do it that way?Thanks so
much for the input.
Jason
817R
On 13-Dec-08, at 3:13 PM, Ken wrote:
Jason
Hi all
under there.
Appreciate the help
Jason
817R
Jason
Actually I always figured that the braces were indeed mostly to tie the
door posts to the firewall. Imagine the tube being pulled firmly as the
engine mount tries to pull the firewall sideways. That pull will also
try to move the instrument panel so I'd recommend a gusset at the bottom
corner of the panel at the bend if you change the brace direction a few
degrees. Don't know if MAM would agree but there isn't a lot of choices
there.
Note that some folks also put a gusset under the glareshield at the top
of the instrument panel where the bend is as well as apparently there
have been some cracks reported in the glareshield there. Same situation
with the firewall pulling sideways I believe. I put gussets on the top
and bottom of the panel.
Thanks Ken
more to stiffen
much for the input.
Jason
817R
Jason
Hi all
under there.
Appreciate the help
Jason
817R
Rebecca Brownell
Thanks a lot,That's good thinking.I'll put gussets both top and
bottom.That otta hold'er!
Appreciate the input.
Jason
On 13-Dec-08, at 10:57 PM, Ken wrote:
Jason
bottom
few
choices
there.
top
situation
Thanks Ken
more to stiffen
much for the input.
Jason
817R
Jason
panel
kpierson
Post by kpierson » Sun Feb 19, 2012 5:07 pm
Jason: THIS MAY, OR MAY NOT BE AN OPTION, BUT WHEN I
MOVED THE INSTURMENT PANEL BACK I MADE THE FACE OF
THE PANEL 2'' WIDER, AND MADE THE TWO ANGLE PANELS
SHORTER. SO THE ANGLE TO THE FIREWALL REMAINED AS PER
MAM SPECS.
HOWEVER , TO DO THIS I HAD TO BUILD A COMPLETE NEW
INSTURMENT PANEL
On 12/13/2008 7:39 PM, brownell@candlelight.ca wrote to rebel-builders:
-> Ken
-> Thanks a lot,That's good thinking.I'll put gussets both top and
-> bottom.That otta hold'er!
-> Appreciate the input.
-> Jason
-> On 13-Dec-08, at 10:57 PM, Ken wrote:
-> > Jason
-> > Actually I always figured that the braces were indeed mostly to tie
-> > the
-> > door posts to the firewall. Imagine the tube being pulled firmly as
-> > the
-> > engine mount tries to pull the firewall sideways. That pull will also
-> > try to move the instrument panel so I'd recommend a gusset at the
-> > bottom
-> > corner of the panel at the bend if you change the brace direction a
-> > few
-> > degrees. Don't know if MAM would agree but there isn't a lot of
-> > choices
-> > there.
-> > Note that some folks also put a gusset under the glareshield at the
-> > top
-> > of the instrument panel where the bend is as well as apparently there
-> > have been some cracks reported in the glareshield there. Same
-> > situation
-> > with the firewall pulling sideways I believe. I put gussets on the top
-> > and bottom of the panel.
-> > Ken
-> > Rebecca Brownell wrote:
-> >> Thanks Ken
-> >> I did trim the panel back as well which keeps the same space behind
-> >> the panel.I was thinking that I could do what you seem to have done
-> >> in changing the angle a bit and reinforcing the corner of the
-> >> panel.just wasn't sure if this was acceptable or not.The braces are
-> >> more to stiffen
-> >> the panel than the firewall isn't it?It's not a huge correction,I'd
-> >> say 4 or 5 degrees.Do you think I'm OK to do it that way?Thanks so
-> >> much for the input.
-> >> Jason
-> >> 817R
-> >> On 13-Dec-08, at 3:13 PM, Ken wrote:
-> >>> Jason
-> >>> I don't have dimensions but I can tell you that I do seem to recall
-> >>> extending the brackets on the firewall out a couple of inches aft to
-> >>> make the angles work. I assume you did cut back the side panels of
-> >>> the
-> >>> instrument panel to pull the panel rearwards.
-> >>> I believe I also changed the angle the tubes meet the instrument
-> >>> panel
-> >>> at a tiny bit. I already had a very strong channel with reinforced
-> >>> corners under the panel otherwise that might not be a good idea.
-> >>> Ken
-> >>> Rebecca Brownell wrote:
-> >>>> Hi all
-> >>>> I need to double check some measurements.I'm installing the dash
-> >>>> braces and they aren't lining up just right.
-> >>>> I moved the firewall back as per manual and wanted to know the
-> >>>> distance from the face of the pannel to the firewall,
-> >>>> or from the rear edge of the upright's on the cage to the face of
-> >>>> the
-> >>>> pannel.The problem is the angle of the bends in the dash
-> >>>> pannel have changed when shortening and the braces don"t meet
in
-> >>>> the
-> >>>> middle of the firewall.If someone wouldn't mind checking those
-> >>>> dimensions for me it would tell me what the heck is going
-> >>>> under there.
-> >>>> Appreciate the help
-> >>>> Jason
-> >>>> 817R
Rebecca Brownell
Thanks but just changing the angle a bit and making a couple brackets
worked very well.Still lots of room behind pannel,not really an
issue at all.Thanks for the input though.Appriciate it.
Jason
817R
MAM SPECS.
INSTURMENT PANEL
builders:
-> Ken
-> Jason
-> > Jason
tie
-> > the
firmly as
-> > the
will also
-> > bottom
direction a
-> > few
-> > choices
-> > there.
-> > top
there
-> > situation
the top
-> > Ken
-> >> Thanks Ken
behind
done
braces are
correction,I'd
Thanks so
-> >> Jason
-> >> 817R
-> >>> Jason
recall
aft to
panels of
-> >>> the
instrument
-> >>> panel
reinforced
idea.
-> >>> Ken
-> >>>> Hi all
dash
face of
-> >>>> the
in
-> >>>> the
-> >>>> Jason
-> >>>> 817R
I like this idea. On my panel the flight instruments are on a floating
subpanel so the dash is almost cut all the way through there and also
where the radio stack is. It would have been simple and invisible to
widen the existing panel by two inches. Of course I didn't know that
back when I fitted the panel...
Jason
817R
MAM SPECS.
INSTURMENT PANEL
bransom
Post by bransom » Sun Feb 19, 2012 5:07 pm
One thing I've kept wondering through this thread is....
If the dash is structural, as is said for the Rebel line, how does one know
where and how much can be cut away for a sub panel? (let alone cut away for
instruments/radio themselves).
-Ben/ 496r
On 12/17/2008 8:49 PM, klehman@albedo.net wrote to rebel-builders:
Jason
817R
MAM SPECS.
INSTURMENT PANEL
Post by Wayne G. O'Shea » Sun Feb 19, 2012 5:07 pm
It's structural in the sense that it helps keep the carry thru cage square
and gives it some support from becoming a parallelogram. As long as it has
enough meat left in it to be torsionally resistant you're fine. The main
thing is the dash braces correctly installed... I even like a second set of
tubes at the top of the panel as well...and be sure to make some semi-circle
doublers for the "glare shield" deck at the isntrument panel
corners....otherwise over time it will buckle in those locations.
Sent: Thursday, December 18, 2008 8:15 PM
Subject: Re: [rebel-builders] Dimentions-dash
know
for
-Ben/ 496r
Jason
817R
bransom
Thanks Wayne
-Ben
On 12/18/2008 4:25 PM, oifa@irishfield.on.ca wrote to rebel-builders:
know
for
-Ben/ 496r
Post by Drew Dalgleish » Sun Feb 19, 2012 5:07 pm
My glareshield buckled at both corners and was starting to crack so I
replaced it with .032. I also have a crack at the bottom of the panel that
I stop drilled and added a V shaped piece to fill the gap top and bottom
where the panel changes direction.
At 07:29 AM 19/12/2008 -0900, you wrote:
Thanks Wayne
-Ben
semi-circle
know
for
-Ben/ 496r
Stop landing on one float Drew !! lol
Sent: Friday, December 19, 2008 5:23 PM
Thanks Wayne
-Ben
square
has
semi-circle
I didn't know you were watching :)
Thanks Wayne
-Ben
semi-circle
