i am replacing my front lower corner wraps right now,
can anyone tell me if they got replacements from murphy or made and bent
their own,
murphy currently sells corner wraps of .025 sheet but i want .032,
can make my own from old piece but dont have equipment to bend properly,
any suggestions
Mike#007
EOM
Hi Mike
The part number you are looking for is fus-452. This is the .032 replacement
part.
This is from my notes ... so I think it is still a current part.
Jim LePard R254
part.
Jim LePard R254
I thought the new corner wraps WERE .032 - they have a DIFFERENT
part number than the old ones. The new ones have the Elite part number.
(First ones were FUS-10, later upgraded to FUS-70, now FUS-532 ????
- not sure of the new numbers....)
You are probably best to use the factory wraps - it's not an
easy part to bend ....
-------------------------------orig.-----------------------------------
---------*i am replacing my front lower corner wraps right now,
their own,
any suggestions
Mike#007
EOM
Mike,
Another couple of thoughts .....
It's probably not worth the hassle of replacing those wraps if
you're going with the 912 .... you'll end up with a bunch of oversized
holes...
If you DO replace them, many builders now are <NOT> trimming these
wraps - just let them overlap the floor, and the side panel, and put in
another row of rivets. This gives a bit more stiffness, where needed.
--------------------------orig.------------------------------------------
holes...
their own,
any suggestions
Mike#007
EOM
