[rebel-builders] cowling...
Post by Drew Dalgleish » Sun Feb 19, 2012 5:02 pm
At 10:10 PM 11/17/2008 -0500, you wrote:
Is someone have ever try to modify / fit a Cessna, Piper or other brand
of metal cowling to fit on a Rebel?
Jean
Rebel 747R
Hi jean I have a tri-pacer nose bowl on my rebel. There was no way to make
the rest of the cowl fit though. I just followed the drawings in the back
of the manual to make my cowl.
Jean Poirier
Post by Jean Poirier » Sun Feb 19, 2012 5:02 pm
Hello Drew
You had instruction for cowling in the back of the manual? I did'nt! I
will ask MAM
Jean
Jean Poirier
Pr
mike jones
Post by mike jones » Sun Feb 19, 2012 5:03 pm
Is that a metal of fiberglass cowl, perhaps you could post it if possible if
its not to long
mike
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Jean
Poirier
Sent: Tuesday, November 18, 2008 7:55 AM
Subject: RE: [rebel-builders] cowling...
Hello Drew
will ask MAM
Jean
Jean Poirier
Pr
Post by Drew Dalgleish » Sun Feb 19, 2012 5:03 pm
It's a metal 2 door cowl. But I think you're better off searching the
archives for four door cowl pictures.
At 06:16 PM 11/21/2008 -0500, you wrote:
[quote]Is that a metal of fiberglass cowl, perhaps you could post it if possible if
its not to long
mike
Poirier
Hello Drew
will ask MAM
Jean
Jean Poirier
Pr
Ron Shannon
Post by Ron Shannon » Sun Feb 19, 2012 5:03 pm
Roger Hoffman's excellent work on a 4-door cowl is shown at
http://tincantimes.dcsol.com/4dCowling.htm .
FWIW, photos of my still-in-progress attempt at a 4-door behind a small
Jabiru nose bowl are at http://n254mr.com/image/tid/65 For more text and all
the gory, verbose details can be found with a search on "cowl", which gets
you to http://n254mr.com/search/node/cowl
http:n254mr.com
On Fri, Nov 21, 2008 at 4:04 PM, Drew Dalgleish <drewjan@cabletv.on.ca>wrote:
