[rebel-builders] Question re 1800 float weight increase
Post by Walter Klatt » Sun Feb 19, 2012 7:55 pm
The 1800s might have heavier skins? Also, net weight is a variable number
depending on which wheel gear you are replacing. Typical empty weights of
Rebel 1800 amphibs really vary too, anywhere from 1100 to 1250, depending on
engines, props, finishing, etc. One of the local Rebels here weighs more
than 100 pounds more than mine, just because of how it was built with mods
and options.
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of C&P
Kucera
Sent: September 25, 2008 5:13 AM
Subject: [rebel-builders] Question re 1800 float weight inrease
Murphy website shows the net increase in weight of the Rebel for the 1800
straight floats as 200 lb and for the 1500 straight floats 146 lb. Each 1800
float weighs only 6 lb more than a 1500 float, hence the net increase in
weight for the 1800 should be only 146 + 12 = 158 lb, where does the 200
come from?,...a typo?...for the last 10+years?
The only thing I can think of is that the struts for the 1800 are heavier
gauge, or the 1500s use only one rudder, or ???
Paul Kucera
Reb 453 Ontario
Keith Leitch
Post by Keith Leitch » Sun Feb 19, 2012 7:55 pm
Walter,
Post by Bob Patterson » Sun Feb 19, 2012 7:55 pm
Thanks Paul !
You've found an error that need correcting - we'll
have to weigh a current set of floats. Walter is correct -
over the years, we have increased the skin thickness
on the larger floats, and these float weights are likely
the old, original weights. The weight increase has probably
been updated along the line, but not the empty weight.
Anyone out there weighed their floats separately ???
If I can get several examples, we'll update the numbers.
As Walter points out, aircraft empty weights vary quite widely,
so the total aircraft empty weight isn't much of a guide.
Both sizes of floats have 2 water rudders, which
makes them a delight to taxi ! If you are still planning
a light Rebel, with a Rotax 912, the 1500's will work well.
bobp@prosumers.ca
1800 float weighs only 6 lb more than a 1500 float, hence the net increase
in weight for the 1800 should be only 146 + 12 = 158 lb, where does the
200 come from?,...a typo?...for the last 10+years?
Paul Kucera
Reb 453 Ontario
Keith Leitch
I have a set of 1800 Amphis still in the crate. Do you know when/what year they increased the thickness?
Keith
--- On Thu, 9/25/08, Bob Patterson <bobp@prosumers.ca> wrote:
Subject: Re: [rebel-builders] Question re 1800 float weight increase
Date: Thursday, September 25, 2008, 11:28 AM
Thanks Paul !
bobp@prosumers.ca
Paul Kucera
Reb 453 Ontario
WALTER KLATT
Post by WALTER KLATT » Sun Feb 19, 2012 7:55 pm
Keith, first, no problem with contacting me directly, and I can give you a lot more detail about my 360 Rebel. Use the email address that I use here to subscribe to this list.
Would like to say a few things too, though, for the benefit of the rest of the list. The 360 is not endorsed by Murphy for use on the Rebel. There are concerns about the tail integrity and gust loads at higher speeds. That is why Murphy came out with the Elite, which has a bigger and stronger tail, not too mention many structural improvements in other areas. While the Elite is heavier, I have actually been quite impressed with the performance of Dennis' 360 Elite on the 1800 amphibs. It is not that far off from my Rebel. I think his bigger wing area with Murphy's new tips and the VGs help him, too. Suffice it to say, I have more respect for the Elite model than I used to.
On the Rebel, I would only use the 360 on the floats. Otherwise, on wheels, you would be risking going too fast, too steep a climb angle for gravity feed, and just way too much power that you would be just wasting. I can't see how you could even break in the engine on wheels, as you would be way past VNE with in any kind of load on the engine.
And performance with my old 150 hp 320 was already very good. The only reason I wanted the 360 is to go into the higher alpine lakes here locally, where take-off times are dramatically affected at the higher altitudes. For example, if your Rebel is loaded, so that it takes more than 30 seconds to get off the water at sea level, you won't get off from a 3000 foot lake, unless it is very cool and you have a good headwind.
Regarding fuel usage, my 360 is actually more efficient than my old 320. I save about .5 gph when cruising at the same speed. I believe the main reason for that is my electronic ignition. Or I can go 5 mph faster with the same usage, which is what I generally do. Most of my cruising is at 7.5 gph.
Date: Thursday, September 25, 2008 8:22 am
Subject: RE: [rebel-builders] Question re 1800 float weight increase
Walter,
Would it be possible to contact you via personal email in
reference to your O-360? I have know idea what engine I will be
using yet but yours sure sounds like a ball!! Fuel consumption
may be an issue though.
Got several friends with SuperCubs I would like to impress. :)
Keith R661
Date: Thursday, September 25, 2008, 9:05 AM
variable number
weights of
depending on
weighs more
with mods
and options.
Behalf Of C&P
Kucera
the 1800
lb. Each 1800
increase in
the 200
are heavier
Paul Kucera
Reb 453 Ontario
Hi Keith !
I don't, but it was fairly early - yours are likely the latest.
Are they factory built ??
If you do uncrate them, I'd appreciate it if you could
weigh them & let me know ... I hope to get a few others,
so we can get an average.
bobp@prosumers.ca
they increased the thickness? Keith
Thanks Paul !
bobp@prosumers.ca
1800 straight floats as 200 lb and for the 1500 straight floats 146 lb.
Each 1800 float weighs only 6 lb more than a 1500 float, hence the net
increase in weight for the 1800 should be only 146 + 12 = 158 lb, where
does the 200 come from?,...a typo?...for the last 10+years?
heavier gauge, or the 1500s use only one rudder, or ???
Paul Kucera
Reb 453 Ontario
Keith Leitch
Bob,
LOL!! Mine aren't even built yet. I have had them 9 years, I think. They were shipped to me either in 1999 or 2000. I tried to start on them when we were stationed in Germany but our orders were cut short and we were transfered back stateside then to Hawaii so I left them in the crate. Worked on a wing while I was back and forth from Hawaii. Almost been thinking of selling them but I know it would cost more later to replace them and since the money is already spent it isn't a big deal.
Keith
Date: Thursday, September 25, 2008, 12:31 PM
Hi Keith !
bobp@prosumers.ca
Thanks Paul !
bobp@prosumers.ca
lb.
net
where
Paul Kucera
Reb 453 Ontario
Keith Leitch
Thanks Walter. You probably answered most of my questions already. Most of my flying is here in Northern Minnesota on small strips and since I am in the land of 10,000 lakes there are LOTS of small lakes. I currently fly an 7AC-CONV on floats with an O-235 and it does well solo but with a passenger or a load there is the occasional pucker factor. :)
Garry
Post by Garry » Sun Feb 19, 2012 7:55 pm
FOKM's floats which are amphibs (1500's originally stretched to 1800's
with addition of the storage compartment) have an exchange weight with
tail dragger die spring gear of 258# measured recently. Floats are
generally as original but have been repaired due to a hard landing on
water a while back so they might be a few pounds heavy - unknown.
Garry
Bob Patterson wrote:
Thanks Paul !
C&P Kucera
Post by C&P Kucera » Sun Feb 19, 2012 7:55 pm
Thanks Bob, yes Im still planning for the 912S
paul
Sent: Thursday, September 25, 2008 12:28 PM
Thanks Paul !
bobp@prosumers.ca
increase
Paul Kucera
Reb 453 Ontario
Post by Ken » Sun Feb 19, 2012 7:55 pm
Mine are 0.040 forward bottom skins and top deck.
0.032 rear bottom skins. 0.020 side skins.
1800 amphibs shipped in 1998, ser# 043 I believe.
Only heavier skins that I've heard of were by special order AFAIK.
Keith
Post by Wayne G. O'Shea » Sun Feb 19, 2012 7:55 pm
Original kits were .032 forward bottom skins/.025 rear bottoms/20thou sides.
Sent: Saturday, September 27, 2008 12:52 PM
Keith
Keith Leitch
Ken,
Thanks. I'll have to check mine when ever I get around to moving enough stuff to get into my crate.:) Before I ordered them I visited a local float manufacturer and he told me the Murphy floats were a little "thin" and that he would put thicker skins on the bottoms. Can't remember what he suggested but seems he did recommend .040.
Keith
Date: Saturday, September 27, 2008, 11:52 AM
Keith
Remember.. staying light is the secret of flight !
Howards original set of 1800's (with .032/.025 bottoms) went 7 seasons
without as much as a scratch in the bottoms. Of course he wasn't fishing
back lakes either!
I have the .040/.032 bottoms on mine. I've hit some rocks while taxiing thru
lake narrows and still not a dent in them.
Sent: Saturday, September 27, 2008 12:54 PM
Ken,
Keith
year
Keith
Hi Paul !
There was a typing error on the web site, on the
weights for the 1500's - it's now fixed, to match the
float brochure.
I'd still like to get some actual weights from folks -
both the floats themselves, and the difference in
empty weight between wheels & floats. I know this
varies considerably, depending on how you built
the floats, and the type of wheel gear you have ...
Please post those weights - whenever you get
to changing over.... Thanks !
bobp@prosumers.ca
paul
Thanks Paul !
bobp@prosumers.ca
increase
Paul Kucera
Reb 453 Ontario
