SR engines?
Charles Skorupa
SR engines?
Post by Charles Skorupa » Fri Feb 17, 2012 11:27 pm
Hmm..... I wonder if that would also be a possible engine choice for the
Rebel Elite. It can handle an 0-360 weight. Don't know about more than 180
hp, though. Cowl might need to be longer, which wouldn't hurt the looks
any. I hear reports from Cessna drivers who have switched to the Franklin 6
cyl that it is very smooth. Someone said it has a vibration damper
standard, but I have no details other than evesdropping on some hanger talk.
- Chuck Skorupa -
Elite S/N 500
Sent: Monday, October 09, 2000 5:37 AM
Subject: Re: SR engines?
On 8 Oct 2000, at 22:47, Bob Patterson wrote:
Interesting, the Franklin and O-540 are about the same size, but the
Franklin is 80lbs lighter.
THAT <IS> impressive !!! Are these weights inclusive of all
(identical) accessories ??? If so, the lighter weight will really
The Franklin is 297lbs, stripped bare. With all acc., except prop
and exhaust system, it comes to 364lbs. (That's with the 7lbs
SkyTec starter.)
According to Lycoming, the O-540-A weighs 374lbs, dry.
Assuming that's stripped like the Franklin, it's 77lbs heavier.
The Franklin may actually be 205HP instead of 220, and I'm
checking into the difference, but it's still only a few pounds heavier
than an IO-360 and should run smoother.
Doing a little math, if I can build a SR at, say 1400lbs, and the
gross is actually raised, that's almost a ton of payload. With 80
gallons of fuel, that's 1470lbs useful load.
That's you, _three_ friends, and the moose you shot. :)
David Parrish
SR engines?
Post by Bob Patterson » Fri Feb 17, 2012 11:27 pm
Hi Brian !
You're not alone in wanting a six-cylinder Rotax ....
Unfortunately, they targetted their design TOO specifically, without
thought for expansion - the exhaust ports are front & back ! If they'd
put them on the bottom, it would have been easy to just add another
row ....
Too bad, because a 6 would be much smoother running than a
4, and a 150 hp 912-6 would have a GREAT power/weight ratio !
(Of course, they ARE working on a six, but it's in the
300 hp. range, a V configuration, and not related to the 912 in
ANY way ) ..... { this is the <worst-kept> secret in aviation } :-)
As for Zoche - welllll, they're good for a chuckle, I suppose.
Wonder what they're REALLY up to ???!!!
------------------------------orig.---------------------------------------
At 01:27 PM 10/9/00 -0400, you wrote:
Hi Bob
I agree with you. I bet the 912S would be a fabulous replacement for the
Lyc. 0235. The performance would be terrific considering the weight loss.
If only Rotax would build a 6 cylinder @ 150 HP, they would have an
unbelievable combination. It would be 100 lb. less than an 0320 &
considerable better on fuel etc.
They could probably build this faster than Zoche will build their 150 HP/
185 lb. radial marvel. But that is another story.
Cheers as Alister would say
Brian #328R
Sent: Sunday, October 08, 2000 11:18 PM
Subject: RE: SR engines?
Ok !! OK !! ;-) It's just an old "guide" - meaning, if you lighten
the aircraft by 100 lb., it will give you approx. the same performance
improvement as adding 10 hp. :-) :-)
I sometimes get my tongue over my eye tooth, and can't see what I'm
saying !! ;-) :-) (Who, me - Wix my Mords ??!! :-) )
That's why I always felt that tossing my old Lycoming O-235C-2C
and installing a Rotax 912-S would probably give me BETTER performance !
The old Lyc. was probably only putting out 100 hp, same as the 912-S,
and the whole installation would have been about 200 lb. lighter !!
This should have resulted in about the performance of a 120 hp. Lyc.
powered Rebel ...
----------------------------------orig.-------------------------------------
At 10:57 PM 10/8/00 -0400, you wrote:
Hi Bob
Per your rule of thumb, a 150 HP engine would weigh 1500 lbs. That would
not leave a lot of room for fuel! I must have you rule of thumb a little
mixed up.
Brian #328R
Sent: Sunday, October 08, 2000 10:47 PM
Hi David !
the Franklin is 80lbs lighter.
help !!! (Old 'rule of thumb' -> 100 lb of weight ~= 10 hp. !!)
That would give the Franklin the equivalent of 228 hp ...
At 07:53 AM 10/6/00 -0400, you wrote:
On 5 Oct 2000, at 23:43, Bob Patterson wrote:
Ouch.
Sure you could! Of course, it'll sort of look like an airplane sitting
on a bar stool...
I was thinking about the cowling reseach NACA did on radial
engines. Thier cowl actually produced thrust, offsetting some of the
flatplate drag of the engine. Still don't know how this compares to
a well cowled flat engine.
Okay.
The Franklin is 25.25H x 31.3W x 37.5L
The O-540A is 24.56H x 33.37W x 37.22L
The O-540 cowl should work, since they're so close in size. One of
the supliers has a premade bedmount for the engine that a mount
can be built on.
David Parrish
SR engines?
Likely a bit much for the Elite !! David did say "IO-360" -
slightly heavier than a regular 360, but the real killer would be
the extra length, putting the weight more forward .....
(Not to mention the real possibility of exceeding redline !!) ;-)
-----------------------------orig.-------------------------------------------
- Chuck Skorupa -
Elite S/N 500
SkyTec starter.)
David Parrish
rebelair
SR engines?
Post by rebelair » Fri Feb 17, 2012 11:27 pm
Hi Bob
Sorry I had to miss the last Rebel meeting. I saw Anna just before I left
that Sunday of the meeting. Had to fly to Indianpolis. It was a really
windy day. Only made 90 KIAS ground speed.
Nice flight i.e. excellent weather & viz. but made me late getting in to
Indy's Class C airspace in the pitch dark. It was hard to find the airport
amongst the city lights.
I would like to hear about Jack Wiebe's prop problem. I have ascertained
that he had a problem with his Warp drive. He called me but by the time I
called him back the next day, he was gone.
Any news?
Regards
Brian #328R
BTW When is the next meeting?
Sent: Monday, October 09, 2000 10:12 PM
Hi Brian !
row ....
Hi Bob
Brian #328R
powered Rebel ...
Hi Bob
mixed up.
Brian #328R
Hi David !
Ouch.
on a bar stool...
Okay.
can be built on.
David Parrish
SR engines?
Hi Brian !
We missed you at the meeting ! Everyone enjoys the opportunity
to see your Rebel and gather photos of some of your unique ideas ...
We have added a few new builders or prospects each meeting.
Anna didn't mention she'd spoken to you until later in the
evening - sounds like you had an exciting trip, and are getting some
real business use out of the Rebel !
I'll go from memory (never good ;-) ) on Jack's prop problems.
It seems they found TWO blades with cracks - one was in the blade,
about an inch long, just outside of the collar at the root. The other
was actually IN the aluminum collar section, apparently. Warp Drive
again showed that they have EXCELLENT customer support, by sending
replacements within a few days ! The cracks were found on different
dates, not both at the same time.
This problem is now well known, and so far, has ONLY appeared
on the 160 hp. versions of the O-320 - NO PROBLEMS with the 150 hp.'s.
It seems to be caused by the stronger power pulses, and the changes
they make in the overall harmonic balance of the engine & prop.
One cure that is working (so far), is to add a harmonic balancer
to the flywheel (8 to 15 lb.... varies). This acts to dampen the
pulses and smooth the engine - only a few in use so far ...
There have been a very few scattered reports of blade cracks
on OTHER types of engines - Continental IO-240, etc. These engines
may also have lightweight flywheels that don't sufficiently smooth
the power pulses. The cracking problems are only showing up now
with the lightweight composite props, as the old metal Sensenich &
McCauley props were heavy enough themselves to provide the
flywheel effect.
Next Rebel Builders of Ontario meeting is Sunday, Nov. 12th,
at 1 pm., at the RAA clubhouse at the north end of Brampton Airport
(CNC3). Everyone welcome, as usual !! Hope to see you there !!
At 10:50 PM 10/10/00 -0400, you wrote:
Hi Bob
Any news?
Regards
Brian #328R
Hi Brian !
row ....
Hi Bob
Brian #328R
powered Rebel ...
Hi Bob
mixed up.
Brian #328R
Hi David !
rebelair
SR engines?
HI Bob
Thanks for the update. Sorry to put you to the trouble. I never want to
miss a Rebel meeting, but, I did not want to miss a long paid business
flight. I can claim mileage so to speak.
It is hard to believe that an extra 6.7% power output of the 160 HP Lyc. vs.
150 HP can/is causing this cracking in the Warp Drive blades. I am not
doubting your comments. But it makes me concerned that by adding just this
small amount of power, the blades are cracking. Which indicates that the
blades are operating way too close to failure mode. Not a good thing
knowing what the outcome of an inflight blade separation can cause.
If the solution is to add a flywheel of this weight, I would have gone
straight to the Sensenich prop right off the bat. I wanted the Warp drive
only to get the weight of the nose. I am very happy with the performance of
the Warp Drive, but, if failure is in my future, I better get it off the
airplane.
Best Regards
Brian #328R
Sent: Wednesday, October 11, 2000 2:57 PM
Hi Brian !
flywheel effect.
Hi Bob
Any news?
Regards
Brian #328R
Hi Brian !
row ....
Hi Bob
Brian #328R
powered Rebel ...
Hi Bob
mixed up.
Brian #328R
Hi David !
SR engines?
Post by Wayne G. O'Shea » Fri Feb 17, 2012 11:27 pm
Your following message has been delivered to the 165 members of
the list murphy-rebel@dcsol.com at 23:32:15 on 11 Oct 2000.
Well gee Brian, do you have 7/16 prop bolts?? If so, there is an aircraft
about 300 feet from yours that, I believe, is possibly wanting a Warp Drive
prop instead of it's 100 hour since new Sensenich to get some weight off the
nose. Both of you have speed cowls, so just swapping the matched
prop/spinner set ups (and some money from you) <should> work for both of you
(if both the engines prop flanges are the same distance from the cowling's
nose)!
Sent: Wednesday, October 11, 2000 9:22 PM
HI Bob
vs.
this
airplane.
Best Regards
Brian #328R
Hi Brian !
flywheel effect.
Hi Bob
left
airport
Any news?
Regards
Brian #328R
Hi Brian !
row ....
Hi Bob
loss.
HP/
Brian #328R
lighten
powered Rebel ...
would
little
presumably
Super
out
rebelair
SR engines?
Hi Wayne
Thanks for chipping in. Yes I do have 7/16" prop bolts. I must admit at
this point, the prop is the only thing that I feel uncomfortable about on
the Rebel. I think I can handle an engine out situation, (easy to say when
you are sitting at a keyboard in the comfort of home), but the thought of a
catastrophic prop blade failure makes me anxious.
What are your thoughts on this? Do you think I am being unduly anxious?
Would greatly appreciate your point of view.
Brian #328R
From: Wayne G. O'Shea [mailto:oifa@irishfield.on.ca]
Sent: Wednesday, October 11, 2000 11:29 PM
nose)!
HI Bob
vs.
this
airplane.
Best Regards
Brian #328R
Hi Brian !
flywheel effect.
Hi Bob
left
airport
Any news?
Regards
Brian #328R
Hi Brian !
row ....
Hi Bob
loss.
HP/
Brian #328R
lighten
powered Rebel ...
would
little
presumably
Super
out
SR engines?
Your following message has been delivered to the 164 members of
the list murphy-rebel@dcsol.com at 08:49:26 on 12 Oct 2000.
Brian, being "unduly anxious" is what will keep you alive in the world of
aviation!!! I have been running a WD prop for 5 1/2 years now. 4 1/2 on a 6
to 1 compression ratio O-235 and a year now on a low compression 150 H.P.
O-320-C2A with no problems. My engine should last for ever as it was a 160
H.P. B2A that I had derated to 150 H.P., so it has a heavier bottom end! I
have had no problems to date <"knock on wood (or carbon fiber)"> with my
prop. Cracks seems to be happening only on the higher compression engines,
due to the harder "hits" on each compression stroke. I guess we MIGHT need
to watch out for the 118 H.P. O-235-L2C's cracking blades with their 8.5 to
1 compression rations also.
Power out glide I can handle, "been there, done that", but the loss of a
blade my also constitute the loss of an engine if you are not fast enough to
shut it down. They just don't glide well that way missing about 300 lbs off
the nose! (although I do know of two gentlemen gliding a J4 to the ground
after lossing the engine, by getting as much of their bodies as possible up
against the windshield!)
Don't know what else to suggest Brain, other than what I have already.
Sent: Wednesday, October 11, 2000 11:42 PM
Hi Wayne
when
Brian #328R
Drive
you
nose)!
HI Bob
vs.
this
drive
performance
airplane.
Best Regards
Brian #328R
Hi Brian !
flywheel effect.
Hi Bob
left
really
airport
ascertained
time
Any news?
Regards
Brian #328R
Hi Brian !
row ....
loss.
HP/
lighten
O-235C-2C
would
little
M14-P
presumably
Super
sitting
out
any
SR engines?
Hi Brian !
No trouble - we just missed you (and your Rebel) :-)
I don't think the problem with the 160 hp. O-320's is caused
by the horsepower per-se - Warp Drive has had no problems with their
props on 180 and 200 hp. engines, and certainly not on auto conversions,
where the re-drive soaks up the pulses.
I believe it is related to the heavier high-compression pistons
"sharpening up" the power pulse - the torque rises more quickly, to a
higher level, and this changes the harmonics. Many parts in aircraft
engines are 'tuned' to avoid problems with harmonic fatigue - from
crankshafts to propellers. I've seen metal props that were shortened
by just one inch, for homebuilt use, that lost about 16" off the end
of one blade after only about 130 hours !! This is the reason that
all certified propellers have very specific tolerances - if the width
(chord) (or the length) goes below the limit, even by 1/16", the
prop must be removed. Unfortunately, some of these props end up as
"bargains" for homebuilders - and MIGHT even work just fine ....
but the risk is there !
The power pulses cause 'ripples' to travel up and down
EVERYTHING, and this flexing eventually causes fatigue - the idea is
to design the structure so that the number of flex cycles is so high
that we won't live long enough to see failure.
Wood (and composite) props are popular because they are much
lighter, and, having much less mass, tend to be less affected by
harmonic vibration - but they're not immune, as we are seeing !!
I guess part of the problem here is that the blades are SO light
that they decelerate quickly after the power pulse, and then are
accelerated rapidly back up again, causing a LOT of flexing. That
is where the 'harmonic balancer' comes in - it adds mass to the
flywheel, reducing the deceleration, and absorbing some of the
fast acceleration, smoothing things out. The additional mass also
can change the natural vibrational frequency of the whole system.
In any case, I thought your engine was only a 150 hp., so
you should have little to worry about. Jack has had, I think, over
400 hours of hard, high load float flying on his prop, and a major
problem was avoided just by inspection & replacement - something
that happens all the time on certified aircraft, too ....
I don't believe that Carmon has seen blade cracks on his
Rebel, and he has over 800 hours of (mostly) float flying !!
This is certainly something we should discuss at the next builders
meeting - how many hours, what kind of flying, and what to look
for....
See you there !!
At 09:22 PM 10/11/00 -0400, you wrote:
HI Bob
airplane.
Best Regards
Brian #328R
Hi Brian !
flywheel effect.
Hi Bob
Any news?
Regards
Brian #328R
Hi Brian !
row ....
Hi Bob
Brian #328R
powered Rebel ...
