FWIW: Several builders advised me that balloons tend to leak pretty badly through the material, and weren't too reliable an indication. They advised me to us a good grade of condom???? While (at my age) I had trouble remembering anything about condoms, I did use these and found that they worked well - to check the tank for leaks, that is.
I fitted my tank quick-drain with an inner-tube valve, and used a bicycle pump to inflate the tank (and condom) - to keep from over pressurizing the tank. After finding several small leaks, and repairing them with the vacuum cleaner trick (the air leaks were fairly obvious by sound - only one was found using soapy water), the condom remained "erect" through the night. Keeping a constant temperature during the test is also important. Be sure and clean the area where you use any soap, since the residue can cause corrosion.
Charlie Starr
Pressure test fuel tanks
Ted what ever you do DONT put 20 pounds of air preasure in your tank. 3to
4 pounds is all you should use and use lung power so you don't break
something. If you need to slosh your tanks I suggest using 3M EC776 it works
very well.
Si
r On 2/11/2008 9:21 AM, tedwaltman@i1ci.com wrote to rebel-builders:
-> Looking for comments & suggestions for pressure testing my fuel tanks
later
-> this week. Here's what I plan to do per input from some A&P friends:
-> - Close/seal the filler cap
-> - Mist (spray) a soapy water solution over the top & bottom of the
-> fuel tank area
-> - Place a big (??) balloon over the fuel drain fitting
-> - Hook up low pressure (maybe 20psi) compressed air to the fuel
-> cross-feed output fitting, thereby.
-> - Inflate the balloon to a reasonable size, then turn off the air
-> compressor
-> - Watch the balloon for perhaps 20 minutes to insure it
-> (hopefully!!) remains the same size
-> - Look for air bubbles while continuing to mist more soapy water
-> over the entire fuel tank area.
-> If I do find leaks (who am I kidding-"If" <grin>), I have some flowable
-> Type-A Proseal. Per another Moose builder, he reported good results by
-> spreading a thin layer of the Type-A Proseal over the offending rivet or
-> seam then putting a very slight suction on the tank using a shop vac and
-> holding the hose over the filler cap with cupped hands. This method
-> resulted in a small bit of the Type-A Proseal being sucked into the leak.
-> I'm aware that one has to be VERY careful not to create any adverse air
-> pressure or risk collapsing/expanding the tank. Hence, this shop vac
-> portion of the procedure has me a bit concerned.
-> Suggestions, alternate approaches, ideas, comments all appreciated.
-> Ted Waltman
very well.
Si
later
-> fuel tank area
-> compressor
-> Ted Waltman
