[rebel-builders] a little question...
Post by Drew Dalgleish » Sun Feb 19, 2012 4:17 pm
as long as the outer corner wraps are rivetted on you should be fine Jean.
At 07:32 PM 1/3/2008 -0500, you wrote:
Fuselage almost done, the inside floor ready to be riveted but not done yet
(another inspection... bofore closing). The tail is sit on cushion (old
aircraft
tire!) and the cabin is sit on landing gear brachets (still on table).
If I put
plywood inside the airplane, everything is strong enough to go in and do
small
work? instead of trying to be the next Sun Circus "rubber man"!
Jean
Rebel 747R
Post by Mike Kimball » Sun Feb 19, 2012 4:17 pm
Agreed. The corner wraps must be in place. However, do as much work as you
can, WITHOUT CLIMBING INSIDE THE TAILCONE, with the upper corner wraps and
the last upper skin just ahead of the vertical stab removed. I was able to
complete everything without needing to climb back inside the tailcone. This
was made easier with the extra small cargo door two bays back from the main
cargo door when I extended the cargo area as many have done. A friend of
mine did climb back there with the upper wraps off and his tailcone buckled.
He had to buy all new skins.
044SR
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Drew
Dalgleish
Sent: Friday, January 04, 2008 4:38 PM
Subject: Re: [rebel-builders] a little question...
yet
aircraft
If I put
small
Jean
Rebel 747R
Post by Ken » Sun Feb 19, 2012 4:17 pm
As long as the tire doesn't push in the skin. I always made sure a solid
piece of wood was under the rivet line at an aft bulkhead so the weight
all went into a bulkhead
Ken.
aircraft
If I put
small
Jean
Rebel 747R
Jean Poirier
Post by Jean Poirier » Sun Feb 19, 2012 4:17 pm
Thanks to all
All cornerwraps/skins riveted. I do not want to go in the tail cone area
but just in the cabin area...
Jean Poirier
Pr
Alan Hepburn
Post by Alan Hepburn » Sun Feb 19, 2012 4:17 pm
What you do is sit the fuselage on a table, then put a vertical piece of
wood up from the table to behind the last bulkhead. Then you can run a
temporary wooden platform supported by a couple of 2x3 wood stringers inside
the fuselage from the cabin to this support, and work inside the fuselage,
lying on this platform. Hope this is clear!
Al
jean.poirier@oxyportneuf.com
Sent: Thursday, January 03, 2008 7:33 PM
Subject: [rebel-builders] a little question...
aircraft
tire!) and the cabin is sit on landing gear brachets (still on table). If
I put
small
Jean
Rebel 747R
jean.poirier
Post by jean.poirier » Sun Feb 19, 2012 4:17 pm
Thank you Al. Yes it is clear, even for me!
Jean
Rebel 747R
On Sun Jan 6 17:36 , 'Alan Hepburn' <ahepburn@xplornet.com> sent:
Al
From: mike.davis@dcsol.com [mike.davis@dcsol.com','','','')">mike.davis@dcsol.com]On Behalf Of
aircraft
I put
small
Jean
Rebel 747R
