I tapped the leading edge of two or three "crinkles" in but they were
only just barely touching. Didn't even notice them prior to flying. In
your case I wonder if new rudder brackets to move the rudder aft a bit
might be the answer. I did put a brass bushing in the bottom bracket.
If you didn't and a sixteenth of an inch is enough, perhaps you could
draw the holes aft that much and fit bushings into your existing brackets.
P.S. I just noticed a one page article in the Canadian RAA magazine
about the Ramble attributed to me. Someone had asked where we went and
I replied in point form. Darned if Gary didn't publish the e-mail.
Wish I'd known so I could of put it in context and made it more
readable and interesting. He must of got the accompanying photo from BobP.
Ron Shannon wrote:
After mounting the rudder, I found several of the stiffening "crinkles"
on both sides of the forward edge of the rudder skin hit the fin post,
significantly limiting rudder travel. At several crinkles, the
interference is substantial, including most of the crinkle's height off
the rudder tube. Has anyone else experienced this and/or how should it
be fixed?
254R
