[rebel-builders] Prop and Gear Reduction Calculator
Post by Ken » Sun Feb 19, 2012 12:20 pm
A larger diameter prop results in more thrust per hp at low to moderate
speeds. Less energy wasted by giving a larger mass of air a smaller
acceleration. Think helicopter. A high reduction ratio lets you run a
larger diameter prop without necessarily getting a high tip speed. I
believe it is prudent to design for lower tip speed both for noise and
energy efficiency. ie I don't believe it is fair to claim that max
thrust per hp. requires such high tip speed for most prop designs. .8M
might be much more reasonable than .9 for under 200 mph airplanes and I
run even slower.
I also believe that generally better all around results are achieved by
running a converted engine closer to max torque rpm than max power rpm.
The power output does not usually drop off quickly if you ease back a
bit from max hp rpm. You are matching the engine to a prop that has a
steeply rising torque demand with rpm. ie the torque demand of the prop
rises with rpm faster than the engine torque rises. My full power
static rpm is essentially my max torque rpm and also where I cruise with
my fixed pitch prop.
Before you change anything why not fly as is. On an SR you can likely
consider a larger diameter prop if needed. It is wrong to assume that a
high tip speed equates to efficiency IMO. Larger diameter yes for our
airspeeds, higher tip speed not necessarily. There are way more guys
wishing for and buying higher ratios for better performance than you
will every find wishing for a lower ratio. But neither the gear ratio
nor the prop diameter is as critical as some make it out to be.
Mike Kimball wrote:
I just uploaded a spreadsheet to the "Software" section that may be helpful
in particular to those of you planning to use an engine that requires a gear
reduction. I have recently discovered that my decision to use a 2.11 to 1
ratio was a bad idea. Based on the max engine RPM I desire I should have
used a lower ratio. I am now faced with trying to modify my gear box or
look at other options. Even for those not using a gear reduction you might
find it useful if you are wondering what diameter prop to use. If you know
your max engine RPM enter that and just enter one (1) for the reduction
ratio and play with the prop diameter to find your optimum prop diameter.
Don't forget to take into account ground clearance. I think the FAA
mandated minimum clearance in a level attitude on the ground is 7 inches.
044SR
Post by Mike Kimball » Sun Feb 19, 2012 12:20 pm
I'm not an aeronautical scientist (although my degree is in Aeronautics) and
I can't personally vouch for the 0.88 to 0.92 range for best thrust. Those
are simply the values I keep running across on the web. Seems like there
must be a reason that float plane drivers like to push their props closer to
mach speed. Noisy suckers. I agree with the notion of running best torque
settings instead of best power, at least for cruise. But that puts my prop
at pretty slow speeds, between 1900 and 2150 RPM and 0.65 and 0.70 mach at
the tips. I can get 0.79 mach at best power which is at 2370 prop RPM.
(That's from memory. I need to dig out my power and torque curves to
verify.) Those best torque prop speeds seem pretty slow for a typical prop.
Even the best power speed seems a tad low. If I was using that big M14 prop
it would probably be fine. At least I have three blades to help absorb
engine torque, although I have to accept some prop performance loss with the
extra prop blade turbulence.
What got me looking at this were the performance figures Steve Bowley is
getting during the early test flying of his Moose with LS1 installed. He is
getting better numbers than me and his gearbox is 1.8. Mine is 2.11. Of
course, there are a hundred other things that are probably contributing to
that, not the least of which is his beautiful, slick, fiberglass cowling.
044SR
Sent: Saturday, September 01, 2007 5:29 PM
Subject: Re: [rebel-builders] Prop and Gear Reduction Calculator
run even slower.
gear
044SR
