strip with the roller behind the tractor and it looks good. A little damp on
the extreme south side last 250" at the west end but good in the centre all
the way down.
Had a Stinson take off last night and expect a kitfox in for a visit
tomorrow.
You can find the coordinates and air map at:
http://www.tally-ho.to/Small-Air%20Map.htm
Jim
Rebel 333
705-458-9669
On 3/30/2007 11:28 AM, "lawsondj@comcast.net" <lawsondj@comcast.net> wrote:
Dale,
Could you please post the photos to the "files"section? I also would like to
see what it
looks like.
Jack, SR193
Ted,, due to mine having to be designed for compression and tension rather
then just tension as a taildragger is. I did mine as you explain, I can
forward photos to you if you want to see,, Dale SR-033 N269DF
