What pickle? Why not contact MAM and get them to straighten things out? I
don't see why they wouldn't provide you with compatible parts to put your
wheels and tubes together. I'm a little confused myself. I don't remember
anything that could be called a "spacer" with my wheels. I just remember
two wheel halves and a tube and everything went together just fine and no
valve extension needed. Maybe I have a different kind of wheel? Did you
opt for the 8.5 upgrade? I have the stock 8.0.
044SR
mike.davis@dcsol.com [mailto:
mike.davis@dcsol.com] On Behalf Of Nancy
Puff
Sent: Thursday, March 22, 2007 11:00 AM
To:
rebel-builders@dcsol.com
Subject: RE: [rebel-builders] JDM wheels, tires and tubes on a moose
Let me expand on that
If you had a wheel rim with a hole drilled out on an angle ....without
a hole in the spacer.... then that would be for a stright valve tube.
If you had a spacer with a hole in the middle and at the top through the
Rim a straight hole that is, that would be for a 90 deg tube with an
extension.
By the looks of things you have the wrong tubes for your wheels and will
need to drill a hole in your spacer
If it's straight valve you want then you will need the hole for that to
be machined through the rim
Hmmph, I guess either way your in a pickle. Sorry didn't have good news.
Nancy
Fred Messinger (fredm)
Sent: Thursday, March 22, 2007 11:01 AM
To:
Subject: Re: [rebel-builders] JDM wheels, tires and tubes on a moose
ARGH!!!...If this weren't so inconvenient, it would be funny.
Thanks Nancy and Steve for your help.
My tire tubes have a straight 2" stem that comes off at an angle from
main plane of the tube. This tube requires the new style wheels.
My wheel spacer has no hole in it. Suggesting a new style wheel.
The wheel ends (the head and bottom of a drum) have holes in
them.......BUT
THE HOLES ARE INSIDE THE RADIUS OF THE SPACER!!!!!! There is no
physical
path from inside the tire to the outside world (which one would need if
they needed to put air in these things).
So the wheels are of mixed breed???? A wheel made with a new spacer
old heads???
So its back to MAM I go?
On 3/22/07, Nancy Puff <
nancy@rotech.ca> wrote:
YAY I WIN!
Nancy Puff
steve whitenect
Sent: Thursday, March 22, 2007 8:39 AM
To:
Nancy beat me to it!!
Steve
nancy@rotech.ca>
Reply-To: <
rebel-builders@dcsol.com>
To: <
Date: Thu, 22 Mar 2007 08:27:31 -0700
Hi Fred
You are by far not the only one that has asked that question If you
have a hole drilled in the spacer you need a 90 deg valve with an
extension If you have a hole drilled in the wheel rim you need a
straight valve with no extension.
Nancy Puff
Sent: Thursday, March 22, 2007 6:51 AM
To:
Subject: [rebel-builders] JDM wheels, tires and tubes on a moose
Hi All,
I couldn't find anything about this in the archives - which may mean
that no one else had this question which, in turn, may mean I'm a
moron.....
For a for a moose with the standard JDM wheel rims and tires that
come from
MAM, how do I get the tube stem to the outside of the wheel? Do I
have
Your Space. Your Friends. Your Stories. Share your world with Windows
Live Spaces.
http://spaces.live.com/?mkt=en-ca
List archives located at:
https://mail.dcsol.com/login username
"rebel" password "builder"
Unsubscribe:
List administrator:
Unsubscribe:
List administrator:
Unsubscribe:
List administrator:
Unsubscribe:
List administrator:
Unsubscribe:
List administrator:
