[rebel-builders] Rebel - Split flaps
Post by Bob Patterson » Sun Feb 19, 2012 11:56 am
Hi Keith !
You have to switch positions of the flapperons, to move
the drive horns on the inboard sections to the root end,
then install about 25 lb of extra tubing, much larger
flap handle, & cable to drive them. Because there are
only 2 hanger brackets, you can't extend them any lower
than they would go with the flapperons without risk.
You will end up with a crippled Rebel with half the aileron
and half the flap ! Don't do it !!! Everyone I know who
tried it switched back as soon as possible .....
Only exceptions are about 7 Rebels in Newfoundland -
for some reason, they seem to think "Cessna did it, so it
must be good" ! They think it works better that way on floats -
all experienced Rebel float pilots in Ontario have chosen
the flapperons.
http://www.prosumers.ca
On Wednesday 14 March 2007 06:46, keith@dcsol.com wrote:
Seeking some information about a retrofit of the split flap ststem on an
airfeame with the wings, flaps, and ailerons all complete. Is there any
disassembly of any components? Are there a lot of new parts to install?
What are some of the pros and cons about them.
steve whitenect
Post by steve whitenect » Sun Feb 19, 2012 11:56 am
Bob
I believe the Newfoundland boys split the flaps because one of them at one
time deployed the flaperons over 80 mph (maybe well over) and the controls
just about locked up. I have testomony to that from one of the guys.
Steve W 637R
Subject: Re: [rebel-builders] Rebel - Split flaps
Date: Wed, 14 Mar 2007 15:54:31 +0000
Hi Keith !
the flapperons.
Get Out Of The House - Ski, Skate & Sun
http://local.live.com/?mkt=en-ca/?v=2&c ... 6E357F!147
Post by Wayne G. O'Shea » Sun Feb 19, 2012 11:56 am
When you go full flaperons on the Rebel...steering is via your feet !...and
once your scare the F out of yourself the first time and realize that, it's
no big deal there after..if you missed the tree that is..... ;O)
Sent: Wednesday, March 14, 2007 12:33 PM
Bob
Steve W 637R
Hi Keith !
the flapperons.
an
Interesting, Steve !
I'd like to meet they guy - he must have HUGE arms !!
It's pretty hard to pull them down at 75 mph, never mind
80 ++ !! In test flying, years ago, I have flown the Rebel
with full flapperon down, up to about 95 mph - still had
good roll control. The control force gets pretty high,
and I certainly wouldn't suggest anyone should do that !
If he was strong enough to pull the flapperons down
at high speed, the control force shouldn't have been a
big deal for him ..... I guess that's how rumours start !
In any case, the solution would be to watch & control your
speed, not butcher the airplane !! Even with half the
flap area, if he goes too fast, he risks ripping them off !!!
On Wednesday 14 March 2007 16:33, steve whitenect wrote:
Bob
Steve W 637R
Hi Keith !
the flapperons.
steve whitenect
This was quite a while ago (over 10 years ago) when I was still living on
the Rock but the lock up was such that there was no aileron control. From
what I can remember it was enough of a scare that he split the flaps.
Control came back with a decrease in airspeed but it was enough to make a
decission right then and there to modify the system. Actually the guy isn't
very big!
Steve W
Date: Wed, 14 Mar 2007 18:08:07 +0000
Bob
one
controls
Steve W 637R
Hi Keith !
the flapperons.
on an
any
install?
Take A Break From The Cold And Have Some Fun Indoors
http://local.live.com/?mkt=en-ca/?v=2&c ... 6E357F!142
Well, as I said, that is how rumours start. It might have been his
perception that the ailerons were too stiff to move - but that is
impossible ! No matter how much load he put on the flapperons,
they would still give roll control if they were moved - and there
is no way that loading them could jam the mechanism as he claims.
If he believes that he can lower the flaps at a higher speed
or larger angle because they are split, he is wrong, and endangering
his Rebel. All he has accomplished is lightening the force required
to move the ailerons - as well as reducing their effectiveness by
one-half ! He has also made the flaps much less effective by
reducing their area. Removing the ability to alter the whole
airfoil section also removes the possibility of having a reflex wing
(negative flapperon) which gives a cruise speed increase and
a better ride in rough air, by getting rid of excess lift.
That's what makes homebuilding interesting - everyone gets
to do what they think is best .... ;-)
very big!
Steve W
Bob
one
controls
Steve W 637R
on an
any
install?
Full flaps in my Rebel...where they actually stay down somewhat more than
the standard Rebel using a teleflex cable...gives minimal roll if anything
as there isn't enough differential of the barn doors at that point. Steering
control is via the rudder pedals. Jam one to the floor and point a/c where
you want to go and when you get there jam the other pedal down to line back
up with the runway.
Sent: Wednesday, March 14, 2007 5:10 PM
on
isn't
very big!
Steve W
On Wednesday 14 March 2007 16:33, steve whitenect wrote: one controls on an any install?
Clay Smith
Post by Clay Smith » Sun Feb 19, 2012 12:00 pm
Hi Steve and Bob,
Steve, I just wanted to point out that our friend Tom did have an electric
motor directly linked to the "modified" mixer to extend the flapperons. So
he likely had a lot more flapperon deflection than the maximum recomended
3-notch teleflex cable set-up.
Bob, send me your mailing address so I can get that fibreglass tail skid to
you.
Clay
Rebel 460
Sent: Wednesday, March 14, 2007 5:40 PM
on
isn't
very big!
Steve W
Post by Bob Patterson » Sun Feb 19, 2012 12:00 pm
Hi Clay !
Thank you very much !!! There is always "a story behind the story"!
I'm so glad we have this forum to expose the truth !
As I said, it's impossible for the standard flapperon mechanism to
jam, or 'lock up', as the original story went ..... Now we know - it
was a MODIFIED flap system, with an electric motor -- so ANYTHING
is possible ! Don't know why folks want a motor - the flapperons
are a 2-finger deal, not a lot of force needed, and the mechanism is
dead simple. Yes, it has some play & flex - but that seems to give
a bit of a safety margin in case of overspeed, and it works great !
Thanks for offer of the fiberglas tail spring - I'd forgotten about it !
I'm always happy to find one, as they are getting rare, and I'm
one of the few who prefer them ! I'll send offline ....
On Tuesday 20 March 2007 13:52, Clay Smith wrote:
Hi Steve and Bob,
you.
Clay
Rebel 460
on
isn't
very big!
Steve W
steve whitenect
Post by steve whitenect » Sun Feb 19, 2012 12:00 pm
Hi Clay
I couldn't remember what Tommy had for a setup at the time but I do remember
the conversation and his concern. He is flying one of the last two engines I
rebuilt before leaving the Rock. If your in touch with Tommy, I wonder how
many hours he has on the Rebel now? Ken Beanlands snr (Rebel)sent some
pictures to Gilbert Tessier (Elite) of Tommy's plane. Very pretty plane with
a simple scheme. I didn't even recognize it! Great memory!
Steve W 637R
Date: Tue, 20 Mar 2007 10:22:26 -0330
Hi Steve and Bob,
you.
Clay
Rebel 460
on
From
isn't
very big!
Steve W
guys.
This March Break, Have An Outdoor Fun-For-All!
Clay Smith
Hi Steve
Tommy's airplane is beautiful ! The inside looks even better. While
building mine I often dropped by his hanger in Passadena and admired his
workmanship hoping that my airplane would look half as good when done. Far
as I know his engine is still going strong. I'll ask him about the time
when I see him again.
Clay
Sent: Tuesday, March 20, 2007 12:35 PM
Hi Clay
remember
with
Steve W 637R
Hi Steve and Bob,
So
you.
Clay
Rebel 460
From
guys.
steve whitenect
You'd be surprised to know that Wayne Jones built most of the plane. Tommy
built fiberglass moulds of all of the interior which turned out really nice.
And yes, say hello to him for me. He owes me a phone call. Take care
Steve
