Hi Rob
You can try Sealants and Coatings Alberta distribuitors online.
They have Sikaflex but I don't know if you need a special grade.
http://www.sealantsandcoatings.com/dist ... /index.cfm
Nancy Puff
Robert Johnson
Sent: Thursday, March 08, 2007 5:36 AM
Subject: [rebel-builders] Sikaflex 292
Hi guys and gals: Great success with the Moose quick build R.H. wing.
The tank (extended) had no leaks. I temp sealed the six access hatches
with a vinyl tape and tested for a day. After opening up the hatches I
was really impressed with the neatness inside with the proseal fillets
all around. Hopefully the L.H. will be as good. I am now in the process
of mounting the McKenzie STOL cuffs but the SikaFlex 292 is no longer
usable - old and dried up in the sealed container. Maybe it has to do
with the "best before Nov 2004" date. - Ha Ha. Does anyone know of a
Canadian (Ontario) supplier. Local stores do not carry it and the
Marinas are not yet open. Thanks - Bob J
List archives located at: https://mail.dcsol.com/login username
"rebel" password "builder"
Hi Bob Sikaflex 1A is the construction equivilent to the marine grade. You
should be able to get it at some building suppliers. If not there's a guy
in Goderich that stocks the marine grade.
At 08:36 AM 3/8/2007 -0500, you wrote:
vinyl tape and tested for a day. After opening up the hatches I was really
impressed with the neatness inside with the proseal fillets all around.
Hopefully the L.H. will be as good. I am now in the process of mounting the
McKenzie STOL cuffs but the SikaFlex 292 is no longer usable - old and
dried up in the sealed container. Maybe it has to do with the "best before
Nov 2004" date. - Ha Ha. Does anyone know of a Canadian (Ontario) supplier.
Local stores do not carry it and the Marinas are not yet open. Thanks - Bob J
tank (extended) had no leaks. I temp sealed the six access hatches with aHi guys and gals: Great success with the Moose quick build R.H. wing. The
Yep as Drew points out 1A is the construction equivalent and no matter how
many times I've read the chemical specs...there is no difference between 1A
and 292. I use 1A to build floats. There is also a generic out at the lumber
yards. It's just called Sikaflex with no designator (yellow tube..available
in grey and limeston) and best I can tell in the way it cured and
reacts...it's the same as 1a as well. Any of these will definitely suffice
to mount Angus's "ribs".
Sent: Thursday, March 08, 2007 10:59 AM
Subject: Re: [rebel-builders] Sikaflex 292
At 08:36 AM 3/8/2007 -0500, you wrote:tank (extended) had no leaks. I temp sealed the six access hatches with aHi guys and gals: Great success with the Moose quick build R.H. wing. The
supplier.
Bob JDrew
Hi Bob !
I think Jack Weibe found some at a hardware distributor
near Hamilton - maybe you could give him a call ...
http://www.prosumers.ca
McKenzie STOL cuffs but the SikaFlex 292 is no longer usable - old and dried
up in the sealed container. Maybe it has to do with the "best before Nov
2004" date. - Ha Ha. Does anyone know of a Canadian (Ontario) supplier. Local
