One way this problem has been handled is to extend the T
tube down, to allow the drain fitting to be attached to the skin.
This allows the drain fitting to extend outside, where it is
easily accessible --- and, unfortunately exposed to possible
breakage .... Choose the push-up-and-lock type of fitting,
or, better yet, the almost-flush tank drain fittings that
Cessna uses - they are much safer, and a bit harder for
someone to drain fuel on you.
http://www.prosumers.ca
On Wednesday 21 February 2007 06:36, keith@dcsol.com wrote:
realizedAfter familiarizing myself with my Rebel, and the builders manual, I
thethat the origenal builder had not installed quick drains at a low area in
pick-fuselage. I have opened up the lower exterior side skins to expose the fuel
lines and started to reroute them to a low area just aft of the rear LG
Howeverup point. Obviously I will have to install a "T" fitting in this area.
there no provisions to access this fitting after the skins are reattached.
How have others addressed this problem?
