[rebel-builders] Everbrite test
Charlie Starr
Post by Charlie Starr » Sun Feb 19, 2012 11:30 am
Don't know what part of Florida your in - it was 23*F here in NW Florida
last night, and not too warm going to a local fly-in this morning (even with
full front and back seat heat on).
Charlie Starr SR N96CS
Sent: Saturday, December 09, 2006 12:34 PM
Subject: [rebel-builders] Everbrite test
OK guys (and gals ...) I just had four aluminum scuba tanks stripped and
polished during their hydro tests. I am going to coat them with the
everbrite
and subject them to salt water diving, bright sun, rough handling by
others,
bumps, scrapes, expansion and contraction due to filling and temperature
changes,etc. These are 6061 T-6, and have a slide on plastic tank boot to
help hold in moisture (tanks typically corrode under them).
If it holds up under such use, the floats should be a cake-walk. I'm also
doing
my Jeep Cherokee plastic bumper / side panels for a test of high speed
abrasion resistance in the Spring rainy season.
YES, it is scuba diving weather here ... warm water, blue sky Christmas
wishes from Sunny SW Florida!
Checked by AVG Free Edition.
Version: 7.1.409 / Virus Database: 268.15.15/580 - Release Date: 12/8/2006
eric.r
Post by eric.r » Sun Feb 19, 2012 11:30 am
We call that southern Alabama or South Georgia. Florida doesn't start until
south of Orlando!
On 12/9/2006 4:11 PM, cws1932@cox.net wrote to rebel-builders:
-> Don't know what part of Florida your in - it was 23*F here in NW Florida
-> last night, and not too warm going to a local fly-in this morning (even with
-> full front and back seat heat on).
-> Charlie Starr SR N96CS
-> From: <eric.r@dcsol.com>
-> Sent: Saturday, December 09, 2006 12:34 PM
-> Subject: [rebel-builders] Everbrite test
-> > OK guys (and gals ...) I just had four aluminum scuba tanks stripped and
-> > polished during their hydro tests. I am going to coat them with the
-> > everbrite
-> > and subject them to salt water diving, bright sun, rough handling by
-> > others,
-> > bumps, scrapes, expansion and contraction due to filling and temperature
-> > changes,etc. These are 6061 T-6, and have a slide on plastic tank boot
-> > help hold in moisture (tanks typically corrode under them).
-> > If it holds up under such use, the floats should be a cake-walk. I'm also
-> > doing
-> > my Jeep Cherokee plastic bumper / side panels for a test of high speed
-> > abrasion resistance in the Spring rainy season.
-> > YES, it is scuba diving weather here ... warm water, blue sky Christmas
-> > wishes from Sunny SW Florida!
-> > No virus found in this incoming message.
-> > Checked by AVG Free Edition.
-> > Version: 7.1.409 / Virus Database: 268.15.15/580 - Release Date:
12/8/2006
