[rebel-builders] Preping surfaces to cover
Post by Wayne G. O'Shea » Sun Feb 19, 2012 11:16 am
NO! Glue it on and go !
Of course be sure no corrosion on anything before you start. Wipe everything
clean with acetone and then glue the fabric on.
Sent: Saturday, October 21, 2006 7:34 PM
Subject: [rebel-builders] Preping surfaces to cover
I am covering my ailerons with the Poly-Fiber method.
It says to wash all the aluminum parts with Poly-Fiber E-2310 Phosphoric
Acid
Etch and Brightner with a Scotch Bright pad.
Then wash with the E-2300 Conversion coating.
Then prime with Poly-Fiber EP-420 Epoxy Primer.
Then I can start to cover.
Is all of this necessary?
pequeajim
Post by pequeajim » Sun Feb 19, 2012 11:16 am
Ok, thanks, I guess I'm ready to go then
On 10/21/2006 3:47 PM, oifa@irishfield.on.ca wrote to rebel-builders:
-> NO! Glue it on and go !
-> Of course be sure no corrosion on anything before you start. Wipe
everything
-> clean with acetone and then glue the fabric on.
-> From: <pequeajim@dcsol.com>
-> Sent: Saturday, October 21, 2006 7:34 PM
-> Subject: [rebel-builders] Preping surfaces to cover
-> >I am covering my ailerons with the Poly-Fiber method.
-> > It says to wash all the aluminum parts with Poly-Fiber E-2310
Phosphoric
-> > Acid
-> > Etch and Brightner with a Scotch Bright pad.
-> > Then wash with the E-2300 Conversion coating.
-> > Then prime with Poly-Fiber EP-420 Epoxy Primer.
-> > Then I can start to cover.
-> > Is all of this necessary?
Post by Drew Dalgleish » Sun Feb 19, 2012 11:17 am
Acid
I sure hope not.
Post by Ken » Sun Feb 19, 2012 11:17 am
I used scotch brite then acetone then EP420 epoxy primer.
No conversion coating and no phosphoric acid etch.
If you use primer it must be epoxy and have time to harden so that the
other chemicals don't dissolve it.
It says to wash all the aluminum parts with Poly-Fiber E-2310 Phosphoric Acid
pequeajim
Post by pequeajim » Sun Feb 19, 2012 11:20 am
Why the epoxy primer if you were going to cover it?
On 10/21/2006 7:17 PM, klehman@albedo.net wrote to rebel-builders:
-> I used scotch brite then acetone then EP420 epoxy primer.
-> No conversion coating and no phosphoric acid etch.
-> If you use primer it must be epoxy and have time to harden so that the
-> other chemicals don't dissolve it.
-> Ken
-> >It says to wash all the aluminum parts with Poly-Fiber E-2310 Phosphoric
Acid
-> >Etch and Brightner with a Scotch Bright pad.
-> >Then wash with the E-2300 Conversion coating.
-> >Then prime with Poly-Fiber EP-420 Epoxy Primer.
-> >Then I can start to cover.
-> >Is all of this necessary?
Post by Wayne G. O'Shea » Sun Feb 19, 2012 11:20 am
To slow corrosion. You won't be alive when that's an issue IMHO
Sent: Sunday, October 22, 2006 2:23 PM
Subject: Re: [rebel-builders] Preping surfaces to cover
-> Ken
Phosphoric
Acid
Ron Shannon
Post by Ron Shannon » Sun Feb 19, 2012 11:20 am
After looking at the Poly-Fiber manual, I think these instructions refer
to prepping aluminum for painting, not for prep under fabric.
254R
