want is it breaking out when you are trying to steer. To make it break out
you generally need a good tap of the brake to make the tailwheel turn a
little further than the rudder pedals will take it and then it will kick out
and let the airplane swing around.
Sent: Tuesday, May 02, 2006 8:23 PM
Subject: [rebel-builders] Rebel tailwheel
don'tG'day
I am looking for some advice please.
I have replaced the standard Murphy tailwheel with a Scott 3200, but I
littlehave any instructions on how it should be adjusted. Come to think of it I
never found any instructions for the Murphy wheel in the manual either.
What I have done is adjust the springs/chains so that there is just a
whatslack in them and the wheel moves through the full range quite OK. But
orI don't understand is just when the "break out" should occur? Should the
wheel be pulled through to the "break out" position by the springs/chains
stops?should the wheel stop short of breaking out when the rudder hits the
Is the wheel designed to be forced over the break out position by turning
the aircraft or should it be operated by the springs/chains.
I hope that made some sense. It seems rather difficult to explain!
Regards
Ian
