What about pelting your airplane with golf balls? Sort of a 2 for 1 deal.
klehman@albedo.net>
Reply-To: <
rebel-builders@dcsol.com>
To:
Subject: Re: [rebel-builders] Dimpled wings
Date: Tue, 03 Oct 2006 21:11:30 -0400
Spheres are so draggy that dimpling yields significant gains.
Aerodynamic shaping such as a long tapered tail or wing has got to be
even better.
I suspect that teardrop shaped golf balls would likely work better than
dimpled props or wings ;)
Dimple tape doesn't seem to have caught on.
gargus@adelphia.net wrote:
Wacky question
Why do golf balls have dimples? According to aerospace engineer Bob
Thurman. He designs golf balls for Wilson Sporting Goods in Humboldt,
Tennessee.
“The dimples are there to reduce the aerodynamic drag, that would be
acting on the ball if it were entirely smooth. He explains that when a
smooth ball sails through the air, it leaves a big pocket of low-pressure
air in its wake. That creates drag, which slows it down. So if you can make
that wake smaller, then the pressure differential goes down. So the drag
force is actually reduced. The dimples do this by creating turbulence in
the air around the ball. That forces the air to hug the ball more closely.
So instead of flowing past it, the air follows the curvature of the ball
around to the back. The result is a smaller wake, and less drag. A smooth
ball when struck by a driver, would probably carry about 110 yards in the
air and a well designed golf ball is going to carry 250 yards. So that's a
huge difference.â€
